ActionStarCBRxx
- 1
- 6
- Hurst Texas
I agree with dstang and the other posts about pressurizing the system to check for air. I found with mine that if you open up the top vent (black twisty thing on top of the fuel filter base) and then just turn the truck over till diesel comes out the discharge rubber line. (Process for removing air out the line at the fuel filter base in TM) Then turn the black cap to re-tighten and hop in the cab to start the truck again, that it would start right up. My air leak was in the fuel filter base.Most common fuel leaks are fuel filter base and lift pump. Check them first and it could be loosing its prime.
If you cant get the fuel to drain quickly out the line (seconds) then don't keep at it. Pull the lead wire to the IP (pink or purple I dont recall). There is a reference in the TM that dry starting creates a vapor lock.
I also agree that the hot starts is not IP but more likely starter based. Do you have one of the rebuilt gear reduction starters? They tend to not last long when you have starting issues (excessive daily cranking). I ended up going back to the original starter and getting it rebuilt by a good reputable shop.
