What air filter breater duct is this?
BlazerAdventure
Phoenix/AZ
What year and engine is this duct from?
May be a good retro fit for the missing M1009 duct. With a little angle adjustment.
What are the dimensions of a M1009 oval filter canister to duct opening?
scottladdy
CT
I am guessing you want to reduce your intake air temp?
But, have you considered the additional restriction that corrugated stuff will add?
1,806
That is from a gasser. The diesel one has a resonator in it. I can take pics of my burb when I gets home.
blackhueys
-9
mn
i had the diesel set up one with the resonator in it you will need the different battery holders like the civy trucks have which take one battery and put it on the drivers side you will then need to get longer battery wires to make up the difference. If you want to I still have the complete left and right side battery trays I can take pictures of as I removed them for my arctic heater setup the trays are just sitting in my garage there is also a different cooling overflow tank. not a hard install as the inner fenders are the same on both civvy trucks and ours. want to know more ask away
BlazerAdventure
Phoenix/AZ
Thank you guy's.
We have converted to 12v, modified rear battery stand to fit both batteries. I believe we came up with a weight loss of 9lbs on rear stand and no front stand or battery.
We are looking for an inexpensive way to get colder air to intake. I think a gasser duct will be easier to find and retro fit. I may cut the the oval duct attachment out of the air canister and weld in a larger one to fit a different duct if necessary. That way I can use a larger diameter tube to offset corrugated tube resistance.
Does anyone know the dimensions of the air filter canister duct opening. The M1009 is up at a friends getting the roll cage installed.
1StumpJumper
NW Washington
That is the same one I have on my 89 Suburban. It came with a TBI 350 but had a 454 carb swapped in before I got it (who knows what it . There is no room in a CUCV for this set up. It is 6" wide by 18" long. There is 2" of clearance between the radiator and the stock battery tray in my M1008.
I am cheap, have this set up, desire to have this on my truck, and still do not want to use the part that ties in to the radiator support.
I personally would not pay for the part and shipping with the work still involved.
Berk
Phoenix, AZ
Thank's Stump. With my front battery tray gone that box might fit. What diameter is the opening for the duct? My goal is to draw cooler air from the the area next to rad support and use the next size larger duct. I'll mod the filter canister to accommodate the different duct. Finding the right year and model to use so I can look up part numbers has been time consuming.
scottladdy
CT
Just remember that a big consideration for the factory intake design was noise reduction. Not necessarily improved or cooler air flow. If you can get the intake pulses out in front of the radiator support, you dramatically reduce the under hood noise level. A major cause of the noise our trucks make is directly due to the "open" intake under the hood.
Take a good look at the after market induction setups from the major suppliers for various engines. You may be able to piece a low restriction assembly together that will flow well.
Please let us know what you decide to do.
