What antenna do I need for 450MHz?
Autonomy_Lost
1,531
Pennsylvania
I'm looking to install a functional antenna on my M998. I will be connecting it to a commercial radio at around 445-450MHz. I'm not too concerned with the amount of gain, but I want something in the proper frequency range. I'm looking for a military-style antenna with spring base so that it looks correct on the vehicle. I see lots of options on eBay for antennas, bases, and mounts, but I need a complete unit and I'm not sure which whips work with which bases.
Here is what I'm currently eyeing up:
Will that base work with that mount? And where can I find a whip that will work with that base?
19,746
I don't have one - but are you looking at a HAM set for your truck?
If so, do you mind asking what kind of radio you might be installing?
TechnoWeenie
1,669
Nova Laboratories, WA
The military wide band antennas are junk. SWR is usually 3:1 or more and 'gain' is usually measured in the negative...
Almost better off with a 1/4 wave or 1/2 wave on an NMO mount.. but you lose that military look.
Just about any military UHF antenna you find is gonna be for satellite work.
TechnoWeenie
1,669
frank8003
4,985
Ft. Lauderdale, Florida
BPV-220-520 is probably what you're looking for, but good luck finding one at a reasonable price.
only thing I found
TechnoWeenie
1,669
only thing I found
That would be it
Autonomy_Lost
1,531
Pennsylvania
Hmm, okay well thanks for the honest answer. I currently have a 1/4 wave whip antenna which works fine, but I was hoping for something that looks more correct on the vehicle. It doesn't necessarily need to be the exact correct antenna, I'm just going for aesthetics. I'm thinking about rigging up some sort of commercial antenna that I can spray paint OD green, but even with that I'm having a hard time finding something with the right look.
Autonomy_Lost
1,531
Pennsylvania
I might have one of those AS-3449 available
If you do, let me know how much you want for it. I'm not sure if it will work for my application or not. The spec sheet says 10W continuous or 200W peak at 2% duty cycle. I'm thinking it will handle 40W transmissions fine but probably worth calling the manufacturer for some clarification.
sigo
Lieutenant Colonel
400
Leavenworth, KS
Low power handling capacity could be an issue. Most mobiles are around 40-50W.
An AS-3449 antenna is standard for a VSQ-2 EPLRS which transmits 100W on high power. Duty cycle might be a factor since it’s a TDMA FH data radio. Again, I don’t know how the antenna specs would work out for non-standard use. I’m probably overlooking aspects of your application, just offering observations.
Milcommoguy
2,261
Rosamond, CA
Wayback machine... 20 years ago when Murphy Surplus was selling them "cheap" picked up three of them. Coupled up to Motorola MCS2000, 420 to 450, 40 watt rigs. Uses a male "N" connector. VSWR flat across the band and exhibits 4-5 dB gain as published.
AS-3449/VSQ-1 Darn near unbreakable. Works like a million buck for HAM 440 band and the military HD use. Never an issue. Two are still in service.
WA6CAM - WA6VVC, CAMO
TechnoWeenie
1,669
View attachment 844044View attachment 844045
Off topic, but my M1031 had antennas for 2m, 440, general coverage RX (no HF), CB, 2.4 Ghz, 700/800 Mhz, and another VHF 1/4 wave used for a TV antenna, in addition to the reinforced 3/4 pipe flange that I could screw a 10' pipe into, and guy down, if I needed a long wire for HF or the extra elevation, since the top of the pole had a waterproof junction box I mounted an NMO on top of, with RG8 running down the pipe... slipped right through the flange and was watertight when connected, or when not in use it was plugged...
I will be redoing something similar on my deuce, just gotta factor in height this time, heh.
86humv
501
Texas
You hanging from a tree on that shot ?.....oh...thats right ...no trees out there.
