Rifleman
- 3
- 0
- HOT Arizona
After reading other members here talking about checking their axle hub temps i decided to check mine. So today, after driving my M925 for about 20 miles none stop i checked all my hub temps. First i check the front axle hub temps, they were right around 98 to 100 degrees. Next i checked the center axle hub temps, they ran 106 to 108 degrees. Then i checked the rear axle hub temps, they were a little hotter then the others, they were right around 110 to 112 degrees.
So my questions are this,
(1) Should all the hubs run the same temperatures?
(2) Is a spread of 10 to 12 degrees between all my hubs anything to be worried about?
(3) last question, do you guys think the temps i recorded for my hubs to be in the normal range?
