What are "Normal" Noises for the Deuce
Tackettr
Edmond/OK
I periodically hear what sounds like and air valve closing or opening while driving my duece. I hope it is not my front axle since it is air operated. I was thinking it might be the compressor kicking on and off like an A/C compressor might do on a car. Also, about 10-15 seconds after I shut the motor off there is a release of pressure under the hood. Are these sounds normal?? Thanks.
neilhendrix
Reidsville N.C.
RE: What are "Normal" Noises for the Duece
I would say that the pres. release is normal . Mine does the same thing. I`m sure others here will know more than I.
Neil
1,193
It sounds like you are describing the sounds that the air governor makes. All normal.
Lorax
Hampton Virginia
Mine do the pssst air sound after shutdown too. People say these things make a lot of noise, but the giggling coming from the cab always drowns others noises out.
vtach
North Dallas, TX
Noises? There shouldn't be any noises. These are stealthy and undectable military vehicles designed to sneak up on the enemy. You better get yours checked out ASAP! ...lol
1,165
Any noise that bangs that you can hear over the "rrrrRRRRROOOOAAAAARRRrrrrr" should be investigated.
rmgill
14
Decatur, Ga
You'll have to get used to it, then you'll notice that some things are out of place. I heard the odd sheet metal sound that I initially thought was a loose nut somewhere on a fender. Then, after a fuel stop, it was pronounced during load on the engine in 5th gear, both in HIGH and low range...that was a strong clue I had a transmission problem. 5th Gear had lost a tooth.
saddamsnightmare
82
Abilene, Texas
July 18th, 2008.
rofl
Sounds like the Air Compressor Governor to me...... You'll get used to the normal sounds your truck makes, BUT when it comes up with a new one, you'd better look quick or the problems can grow exponentially.....! Remember, if you're an old deuce driver, you probably can't hear anything anyway!! [thumbzup]
Sincerely,
Kyle F. McGrogan
1971 Kaiser Jeep M35A2 Wo/W "Saddam's Nightmare" Desert Storm and Vietnam Veteran Deuce
1968 Johnson Corp. M105A2 Cargo Trailer
1967 Hercules MEP023A gas Gen-Set APU
1963 Swiss Army Cargo Unimog, S.404.114 MB
chuck500cc
DFW Area
Mine sometimes would sound like I left half the wrenches under the hood and there were times the times the thing was as quiet as can be be. Nothing but "C" turbo.
Chuck XD Fan
1,193
WM, Based on conversations in the Mess Tent(chat), I'm pretty sure YOUR "Normal " might be different that most peoples "Normal" ! :lol:
