What are these for?
Dodge man
Fl
Does anyone know what the plugs in the picture might be for? The pins in them and the body size are the same size as the pre-NATO vehicle jumper cable but these use a threaded collar instead of being just push on and the two pins are shorted together. The pins are also centered in the body instead of being off-side like the jumper cable pins are. The green body on these appears to be made of aluminium and they're marked "*/01/*" , "69-61067-3" , "SN 294403" and "A-01". I found them in a surplus store and thought they might be useful for parts but would like to know what they're intended for before I destroy them.
Dodge man
Fl
I think Westy is on to something. Probably used to ground out the shelter components for EMP protection when traveling.2cents
I was thinking along the same lines. But I was thinking that they might be shorting plugs to short the output of a GenSet to prevent an accidental shock while servicing them. Does anyone know of a GenSet or Shelter that has a socket that matches these?
Dodge man
Fl
Dummy loads ?
I don't think so. The impedance is too low (a dead short) so they would just conduct the current instead of dissipating it. Also they don't look like they're made to dissipate heat.
PS I found another marking that I overlooked before. It says "SAFE" in relatively large letters on the end.
kastein
26
Southbridge MA
I would bet on them being safeties for working on gensets, etc like you guessed. Looks like they would fit the 24V power outlet on the back right corner of the cab on a deuce or 5 ton.
EDIT: that is not to say you should try it, as I am fairly certain those power outlets are wired directly to the batteries! :twisted:
