What are these two screws?
277
Belton, SC
On the door just above the access panel, there are two screws (kind of on a diagonal.)
Do they attach to the window regulator? I can't see any screws in that location in the parts tm.
I pulled them out by mistake when I was removing my door latch, and now I can't get 'em back in.
The worst part is the door latch needs a new spring and I'm going to have to take it out again. I need the truck this weekend, and don't want my boy falling out so I'm reinstalling the latch for now. Although I guess he couldn't fall out since I make him wear his seat belt. But I bet he'd get pretty excited if the door flung open!
Man my arms are chewed up!
Barrman
1,730
Giddings, Texas
I don't have my truck here to look at so I can't answer your exact question. However, I have had broken door latch springs. I couldn't figure out a way to install new springs and still have all my finger tips. I would suggest you replace the latch.
Wildchild467
56
Milford / Michigan
You might have to loosen the screws a couple turns that hold in the rest of the window regulator so you can just get the other screws started. Then tighten the rest up. I believe there are 4 screws that hold the regulator in.
277
Belton, SC
Yep I was able to look at it this morning (last night by the time I wrapped up, it was pitch black, and I don't have a shop.. So the lighting wasn't the best)
I believe you are right, and they go to the window regulator. Kinda strange that not one TM or parts exploded view shows screws going into those holes.
The TM does mention taking out 4 though.
dmetalmiki
2,027
London England
You are OK getting them back in if you are a contortionist. Just make sure all the fixing screw are loose to enable some movement.
277
Belton, SC
I got these back in today.. Amazing how much easier it is to work when there's light!
Also the tip to loosen the other 2 regulator screws helped a ton. I was able to get the holes lined up by rolling the window down, just to the right spot.
Thx guys!
Sent from my LG-V410 using Tapatalk
