what are these wires for
nf6x
Feral Engineer
1,630
51
Riverside, CA, USA
Circuit 2 would be the alternator output that charges the batteries. So, if disconnecting that lead at the regulator eliminates the current drain, then it sounds to me like the regulator is bad. I don't know if they're repairable and/or easily found as a replacement part. None of my trucks have the dual-voltage alternator like your HMMWV does, so I don't have any hands-on experience with it yet.
By the way, here's a good reference for what those circuit numbers mean:
M-Series Vehicles Circuit Numbers
hughscpa
Coffeen, IL
They look the same just a different part number. The only thing on the M1113 that is not on the others is the hydralic winch. Could I swap out generators? Will the pulleys swap out?
nf6x
Feral Engineer
1,630
51
Riverside, CA, USA
If they have the same part number on them, then maybe they're interchangeable. I don't have any experience with the dual-voltage alternators.
hughscpa
Coffeen, IL
Well, I just heard from a rep at C.E. Niehoff. He said my two regulators are interchangable!! So I will give it a try this afternoon and hopefully that will fix my problem.
