- 4,522
- 2,618
- 113
- East of Edmond, Oklahoma
It's been tested on the road and works perfect. It's at least a grade 8. Some are grade 10, but I don't have any of those.Nice!
You've used it? I had a bolt(never looked at the grade) and it sucked to remove once bent!
I don't have, or want a M1101/2.I looked for a similar hole in the 1101...nope
You sure your tow vehicle can handle it?!I finished painting over the weekend and I took the M-1101 to it's new owner last night.
My m101s don't lock on when backing.Will someone with an 1101 or 1102 answer why the brakes don't lock on when backing?
Ditto, I have never had an a2 lock up in reverse.My m101s don't lock on when backing.
It is air over hydraulic, which means there is an air diaphragm that operates a hydraulic cylinder. The brakes are hydraulic.where can I get one and this one has air breaks on it .
If your M101A2/3 is loaded and you try to back up a steep driveway, the brakes will activate, if they are working properly.My m101s don't lock on when backing.
