What do you call the three inch ring of soft metal b/t exhaust y-pipe and water fording exhaust pipe?
TOBASH
3,244
Brooklyn, NY
I'm installing a water fording exhaust pipe and I need to buy that ring from a local muffler shoppe. I'd like to call it by the correct name
TOBASH
3,244
Brooklyn, NY
unofficial name is "exhaust donought" or technical name is exhaust flange gasket. I ordered mine from kascar as it looked civy but I could not find the correct one aftermarket.
As always, you’re an awesome fund of helpful info. Thanks!!!
nikojo
103
Wisconsin and Illinois
As an aside and something to consider.......I've seen the fording exhaust stack can spew out indelible diesel exhaust fluid that essentially stains everything it contacts pretty badly. Including the truck itself. Think of an exhaust tattoo lol. So if you are parked next to other vehicles, or garage wall, or wall of house, be careful not to park in those areas.
I have a fording kit but won't be installing the exhaust stack unless I know I'll need it. I'm sure you already know, but unless the truck stalls/turns off, the truck is pumping exhaust through the pipe even if it's underwater. Even if it stalls it's likely to be fine with the regular exhaust as it has to draw up pretty far.
I do like the look and utility of it. Curious to hear what others think.
Retiredwarhorses
4,054
Brentwood, Calif
I’ve advised my customers for years that the exhaust is a problem as you have stated, one customer in particular refused to listen and his new cargo extension was essentially ruined because he didn’t believe me.
M1165A1
793
The High Country, CO
My regular exhaust does a pretty good job of marking the bay floor and my Tahoe . . . I really need to hook up some kind of exhaust hose to remove the fumes outside the garage when I start.
signsup
Atlanta, GA
I took my M998 to a local high school for a veterans day event and one of the youth asked me what the stack was for and I replied that that is how the military could tell if it was a male or female Humvee. I don't think he got it.
I like the look of both the snorkle and snorter, but it does puke all over my slant back.
