What do you think....1979 Kaiser Rotator Boom Wrecker
bulldog_mack13
3/3 ACR
2,968
34
Colo Springs, CO
Theres a BUNCH of guys in the Military Vehicle Collectors Of Colorado , and most of the same guys are on SS that have M816's . Get to know them and maybe join the club , they would be happy to come out and help im sure, Jay
DouglasCo
Douglas Co Co
oh well, it won't be the first boom they've bent. and certainly not the longest. All the m816's have 45k rear winchs right? Thats a big winch. What are the odds that there is other internal damage that caused the case to crack? Or is it like the aluminum deuce winches that crack if the wind blows? I imagine its much harder to find someone who is parting out one of these rigs.
DouglasCo
Douglas Co Co
here is a dealer i ran across in texas. He has a m816 with 5 times the mileage listed at $16,500 and sold so i guess you got a good deal.
http://www.texasmilitarytrucks.com
Do you guys know if they could run duel wheels on the back with that tire/rim combo? They were all originally duel wheeled right? Whats the easiest way to tell if the tires have the run flat inserts in them?
Hub McCaan
Denton, TX
I looked at those tires today - I don't think you could run duals that size on the back. Those tries add almost two feet to the height of the boom when it is raised. Big John can weld Cast Iron so we may check out the winch and see if it is okay and then maybe get him to weld up that crack - it's not too bad.
I parked it last night and this morning there was still 90 psi in the tanks - so at least it holds air well.
More Photos:
http://i261.photobucket.com/albums/ii65/TexomaTrash/arfcom/Photo_020709_001.jpg
http://i261.photobucket.com/albums/ii65/TexomaTrash/arfcom/Photo_020709_003.jpg
http://i261.photobucket.com/albums/ii65/TexomaTrash/arfcom/Photo_020709_004.jpg
http://i261.photobucket.com/albums/ii65/TexomaTrash/arfcom/Photo_020709_007.jpg
jatonka
101
Ephratah, New York
Hey Hub, you oughta look up Dabtl on SS, he's in Denton too. Your 816 wrecker takes all the same parts as the older M543 wrecker. There are lots of them around. The crack might have happened from water in the oil in that case, should check them all for water. Good luck, have fun. JT out
DouglasCo
Douglas Co Co
Thats a neat modification, but a nightmare for crossing ditches. I like the ladder on the boom. I would like to see hydraulic outriggers on the sides like on a backhoe or a real crane.
I saw a couple people say it can be modified to rotate 360 but didn't see where anyone actually said what it takes. Anybody?
Crash_AF
Colorado Springs, CO
As far as I know, there are two stops at the limits that just bolt in under the turntable. I have not done this mod to mine though.
Nice looking truck for $8k
Later,
Joe
m16ty
227
Dickson,TN
The rear winch case is aluminum not cast iron. If it just had some water in it and it froze and craked you may could just weld it up. If something got in a bind and cracked it you may be looking for a new winch.
DouglasCo
Douglas Co Co
Wow, really? Anybody know what that winch weighs without the wire? Just curious, i didn't know there were any aluminum 45k's
m16ty
227
Dickson,TN
The only dealings I've had with the 45K winch is I installed one on the back of a Kenworth. I didn't weigh it but it's heavy. I guess about 400lbs.
The only thing I don't like about the winch is it doesn't have a disconnect lever to free spool the rope out.
Csm Davis
403
Hattiesburg, Mississippi
mine and a few others I know of have busted from abuse of breaking loose under pressure, ripped the end off my cable with 40,000 lbs of track-hoe hanging on it:roll: the backlash messed up the gears just enough that next pull bang:cry: the back end of my truck broke into a bunch of heavy scrap. Winch, drive shaft, jack shaft, chain, and floor plate all toast and had to check my pants:oops: The case on all the Garwood winches are aluminum that I know of and I think you can still get parts from the manufacturer. good luck.
