Br0nc0xrapt0r
- 2
- 6
- Kent City MI
Yep, that's also why I add links, prices, and part numbers to all my threads so others can learn from my research "or mistakes" when they want to do the same mod.
You nailed it, that readout can only read one probe at a time. Auber wrote me that and suggested this readout for both probes. http://www.auberins.com/index.php?main_page=product_info&cPath=5_21&products_id=357Had to check my records. Those are the same part numbers I used. For the EGT I used SYL-1813-24 for the digital readout and TC-KEGT for the probe. I got the longer probe and used a weld in fitting downstream of the turbo as close to the turbo as I could get it. For the boost I used the same SYL-1813-24 with the 303 boost sensor. Unless you got some sort of package deal, the price you listed is a little low. Did you order one readout and two probes? The readouts allow you to hook a variety of probes/sensors to them but you can only have one of them hooked up at a time. There is no way to "toggle" between the probes so if you want to see EGT and boost at the same time you will have to have two readouts and two probes.
A nice feature about the Auber's is that they have a trigger function. If you want to use a water injection system you can set the readout to trigger at a certain boost or temp to activate the system.
BTW - I have four of these. I use red led's for my EGT and oil pressure. Blue for water temp. and green for boost. They really show up nicely at night.
Just to be clear these part numbers I listed will work for Boost OR EGT but not at the same time as the readout will only monitor one probe. So the readout with green LED and the 1/8th NPT EGT probe is $97.50. This price is consistent with what I saw in other threads porting about the unit and is offered as a bundled set in this link: http://www.auberins.com/index.php?m...ducts_id=231:1fdf0ed7cc198e06923460320c7a8fa0Ok so for the gauge I have the boost/egt unit Part number SYL-1813-24 and the EGT probe TC-KEGT and boost sensor AUBER-303 the total is $137.76 not too shabby.
That is exactly what I did. I started with a 1/8" bit and started the truck just before it broke through, and used the proper size bit. The pilot hole made the larger bit go through like a hot knife through butter.A tip about the shavings, start drilling the hole and when you are about to break through start the truck and the exhaust gasses will blow through the hole and remove any shavings.
That's what I did. Sunpro, like $17 online. Light socket is the same as the instrument lights, so just popped in a 24V bulb, and tied in to same.Soft you say? That's good, perhaps they are less likely to crack then. After careful thought I am still going to use that kit fro Auberins but I will buy a cheap anolog boost gauge just because.
Killer! So where did you get the 24v bulb? Vatozone or napa?That's what I did. Sunpro, like $17 online. Light socket is the same as the instrument lights, so just popped in a 24V bulb, and tied in to same.
I have a few spare bulbs from another Instrument cluster I have.Killer! So where did you get the 24v bulb? Vatozone or napa?
Yes, that's the one, but it was like $23 with shipping. That was like 7 months ago.
