What Filter?
glcaines
2,448
Hiawassee, Georgia
That is not a filter. It is an indicator that will tell you when your air filter needs to be replaced. It normally shows green. When the resistance to air flow through the air filter exceeds a certain limit the indicator shows red.
GeoffH
Exeter UK
Hello Gary,
thank you for your reply i am still a bit confused though if it is not attached to anything and simply
bolted to the dash panel How does it work?
sorry if i am being a bit thick.
Geoff
TGP (IL)
33
Metro East IL
You look on the backside between the two mounting bolts?
Should be a copper or plastic pipe going to the Air Filter Canister.
Tom
SETOYOTA
421
georgia
It’s the nuclear bio chemical filter. If it turns red it’s too late for you.
