skysix, yes it’s a sway bar and is currently unhooked, eventually I will either put a quick disconnect kit on or space it down at the frame, doesn’t seem to sway much with it unhooked though.
Guys as far as the compression term, you got me there, that’s wrong. I should have put more time in typing my post, what I should have typed is it takes the shackle out of tension and puts the shackle in compression, I did consider a shackle flip but for this truck I went with the blocks for now.
As far as rear lift springs go, that’s what I found too no one makes lift springs for the rear with high enough weight capacity, but I had seen Alcan Spring recommended for custom building springs, if it doesn’t cost too much that may be the route I go in the future.
