sigo
Lieutenant Colonel
444
Leavenworth, KS
Great mod. Did you fab those boxes, or are they something you purchased? I like the rails with tiedown points on top of the boxes.
Swamp Donkey
The Engineer
126
Gray, GA
I bought them. They are made of 1/8" aluminum. They are the perfect dimensions to fill that spot. One would also fit nicely between the frame rails too. I didn't paint the inside because I'll get them Rhino-lined after I finish. Information and pictures below:
Oshkosh Corporation, Accessories Stowage Box, P/N 3899299 End Use: Oshkosh MRAP All Terrain Vehicle M-ATV, Special Operations Command (SOCOM)
NSN 2540-01-589-6329
Another Ahab
4,903
Alexandria, VA
I like the storage "tray" detail on the lid/top:
- A few bungees criss-crossed across the top of that, and you got additional storage (like for tarps. or a work-mat, that kind of thing).
That's pretty slick.
74M35A2
340
Livonia, MI
Swapped out the electric engine oil pressure gauge for a mil spec mechanical one. VAST improvement in resolution and accuracy. Bought gauge on eBay, but was $70. Thread in 5T Mod section:
Another Ahab
4,903
Alexandria, VA
74M35A2;1758453[COLOR=#ffff00 said:
]Swapped out the electric engine oil pressure gauge[/COLOR] for a mil spec mechanical one. VAST improvement in resolution and accuracy. Bought gauge on eBay, but was $70. Thread in 5T Mod section:
View attachment 577684 View attachment 577685
Your dash is in good shape; clear glass on the gauges, all the gauge ID lettering in place and readable.
A lucky purchase, or have you been working at all that?
rhurey
15
Bothell, WA
Not this week, but mounted the tow bar under the bed. Held in place by friction, don't seem to need to drill the frame.
74M35A2
340
Livonia, MI
Mostly as received. Only thing I did was rubbed the lenses with 3M lens polish, but a few are still hazy. Night shot, cold start, idle:
rhurey
15
Bothell, WA
No safety chain of some sort?
The most they can move if the friction fails is about 2". The U-bolts will have to break for the bars to actually be able to come out. The angle iron is long enough that it can't be pulled through either side while attached to the bar parts, and the collars prevent the bars from sliding through the ends of the U-Bolts unless the bolts break or are removed. So friction and size.
Snowtiger
British Columbia
Picked up a 2 year supply of filters and 2 spare belts (only one style of belt that I need but when you get a 60-70 percent discount take advantage of it). All that's left is a couple of air filters and the rebuild kit upper and lower for my air system. Still stumbling on my oils, after reading on oils its mind boggling all the opinions. So many valid points and personal experiences that help eliminate and decide. This truck has been a pleasure to own and operate I wish they built new trucks like this, odd how were supposed to be in the improved technology era but our vehicles are like BIC lighters these days lol.
General Hood
Fort Towson, OK
:goodjob: That's a deep discount, not found every day! I'm ecstatic to get a 10% military or senior discount
JohnnyBM931A2
Crystal Lake, Illinois
Gotta love the 8.3 with its single serpentine belt :)
brasco
Southeast of Indianapolis, In
Installed Fire Extinguisher in M931A2
I installed a fire extinguisher in my M931A2. The mounting location is the same as the bracket on my M923A2 when I bought it. The bracket itself is different than the USGI unit.
The extinguisher in a 5lb Amerex Purple K unit. The unit itself weights about 10lbs. It appears to fit well in the location shown. I'll probably add this to my other trucks too.
JohnnyBM931A2
View attachment 578651 View attachment 578652
Nice :) I picked up an extinguisher recently.. Probably about the same size as yours. Just need to mount it (mine apparently never had one.) Seems like it fits pretty well where you put it. I might do that as well. After that I just need to find a good way to store my first aid kit, emergency triangle case, and reflective vest inside the cab.
