Another Ahab
4,982
Alexandria, VA
Also ordered the air filter to go with my new filter cage.. Wix 46664 was the correct filter number. Got one for $40.. Not too bad. Between that and the TMG filter cage I'm at $95. If memory serves new military filters are $125. So I've already saved $30, and obviously I only have to buy the cage once. So subsequent air filter changes will only be 40 or 50 bucks, depending on where I get the filter from. That makes me happy
Happy is good; usually better than sad.
mdemars03
El Paso, Texas
Just finished installing my new to me cargo cover and getting my antenna mounted for my RT-524. Also got my MX-7777 surge suppressor installed. Next step is to install the RT-524 mount and radio. Hope to have that done before next weekend.
Another Ahab
4,982
Alexandria, VA
Please. You just "gotta" post a pic, or too many people will be sad
Trailboss
140
Norwood LA
Took the wife and critters to a horse show
View attachment 597578View attachment 597579
Good Show (pun) - I bet that made the other rig owners envious! My only broken bone came from being thrown from a bucking horse. I've got 13 of those pasture ornaments vying for space in the pasture with my motor pool. Wife "your trucks are taking up pasture from my horses." Me "your horses are chewing parts and using my trucks for rubbing posts." Wife "you're spending too much money on those old trucks." Me "my trucks don't eat $1000 of hay every month." You get the idea that there is a an uneasy truce, especially since I also use my MVs to support her horses.
http://www.steelsoldiers.com/showthread.php?77864-What-have-you-done-with-your-5-Ton&p=1622079 - post #44
http://www.steelsoldiers.com/showthread.php?40043-Put-the-5-ton-and-M119A1-trailer-to-work
http://www.steelsoldiers.com/showthread.php?61291-Any-body-use-5-tons-commercially/page2 - post 13
Another Ahab
4,982
Alexandria, VA
Communication they say is the key to a healthy marriage; and it sounds like you two talk a WHOLE lot, so it should be all good! :naner:
fuzzytoaster
3,760
Fort Worth, Texas
Got my LWS installed on my fresh RRAD overhauled truck. Next is the Eyecon light kit, Vic 3 system (missing a few bits), air ride seat, and camo netting in place of the cargo cover. I'm debating on swapping to 395s since this will be my traveling truck and gun truck for airsoft.
mdemars03
El Paso, Texas
Fixed my turn signal issue. Turned out to be a bad ground at the flasher relay on the firewall in the cab. Found a new grounding point for the relay and the turn signals work as they are supposed to.
therooster2001
45
Colorado
Checked my transfer case for air routing mistakes, it was not backwards. Checked the front axle light, and redid the apolstery on the seat back. Prepped my old hard top for a buddy. Waiting for it to warm up a bit to test out 6wd, and to play with the the winch.
