Spyderman
40
Alexandria KY
I got the new super rope I ordered. I put it on today. It looks so much better than the white rope I had on there. I will take a couple pixies when it gets light out.
Also took my 2 year old son down to the train tracks this week to watch the trains. He loves trains. Sat next to the tracks in the back of the truck for over an hour. Not a single train came by. Try again soon.
tobyS
840
IN
I grew up near a winding RR track and we played on a bridge over a creek. We would get up under the bridge when a train came to "feel" the massiveness and power of them starting to accelerate, leaving the valley. We (the neighborhood kids) had an infatuation with the put-puts that came along about every other day. At about 10 yrs old we would grab on and ride a few miles (until jumping off got scary). About 13 I got a minibike and rode across the Wabash River on the open trestle bridge and the roaring river below. I thank God my children never did what I did growing up near that RR...I would not handle it well.
Spyderman
40
Alexandria KY
Across the river from us we can see the tracks. My son runs to the window every time he hears the train. It's almost a mile away. Guns and trains is what he loves.
gottaluvit
Eh, never a challenge for these 6x6s. I remember while stationed in Germany, the truck I was issued never spun a tire in snow or mud. One time I was all excited as we were out training in some sloppy mud and I thought, "Now I can make some rooster tails". Well, that sure didn't happen. The beast just shot like on a 1/4 mile dragstrip with slicks. Have yet to see some tails from these traction grabbing beasts.
Well now, I must say that no longer stands to be the case as I nearly got stuck twice yesterday, pulling my CUCV out. It wiggled it's way out, but barely. Now I know where the wet springs are in my field.
37
TROY, MO
Over the past few weekends, I upgraded my headlight system to 4 54W LED lightbars. I made these plug & play, using factory packard connectors and existing bolt holes. Bottom spot lights are low beams, click the floor switch and the upper flood beams come on along with the lowers with the use of a 50V diode from Radio Shack.
I sandblasted and repainted the front end and as of today, I'm nearly finished installing my train horns, all using factory packard connectors. Hornblasters Shocker 24V kit.
It's time to wake the dead!!
20160226_061722.jpg20160219_164824.jpg20160207_102517.jpg20160207_095343.jpg20160206_220117.jpg20160206_144938.jpg20160204_202600.jpg20160224_163437-1.jpg20160214_190301.jpg
Swamp Donkey
The Engineer
125
Gray, GA
I found these just in time to use them while digging down to my inner axle seal.
New 24V impact wrench powered by slave cable - $15
New military 4x torque multiplier - $15
Being able to loosen lug nuts with one hand and zip them off in seconds for $30....Priceless! :mrgreen:
On to the seal replacement...
In this picture you can see where someone before me had gone in with some pointy object to get at the retainer. They did a number on the spindle lock nut too. Had to clean it up to get the proper socket on it.
Long pause here with no pictures because I was ready to chunk everything in sight due to problems putting in the new seal. This was mainly due to my new seal installer being a little on the short side and it eventually breaking in the end. At this point it was: Truck -1 / Swamp Donkey - 0.
Fabbed and welded up a seal press using a cross bar and push bolt that braces against the inner bolt circle of the knuckle. It was about 4:00am at this point, so a longer seal installer was not happening. The press worked perfect with no more drama. Will be using this in the future since it worked so well. It keeps everything square and sets it in a controlled manner.
The finished product. That's right...I just posted a boring picture of a wheel and tire.
sandcobra164
323
Leesburg, GA
Bumped the fuel on mine slightly with the screw in throttle shaft and put about 40 gallons of filtered waste ATF. Truck seems to like the changes so far. Now it feels like it wants another gear when cruising at 55 mph and doesn't slow at all in the hills. Now to add a new either solenoid as these Cummins 250's don't like 30 degree starts.
37
TROY, MO
i'm sorry for missing the message here, but:
- You're stripping out all your phillips heads, is that what you're saying?
I forgot to quote your post. In drilling out my bearing, I'm not sure if I've gotten all the way thru yet. I've never felt the bit break-thru the steel bearing. I had a buddy tell me his flat head screw is about half an inch inset, so I guess I have more drilling.
gottaluvit
Man, I'm really missing the message. What bearing are you drilling that has screw heads on top?
sandcobra164
323
Leesburg, GA
He's trying to drill out the "tamper proof plug" on the side of his PT injection pump throttle shaft. Behind that plug is one of the fuel adjustments available to NHC 250 power truck owners. The other things that I'd read help include using different "buttons" and a dual fuel line mod.
37
TROY, MO
The guy above me got it correct. There is a steel bearing pressed into the shaft to keep young bucks from tampering with the HP. After you drill it out, your fuel adjustment screw is behind it. If you adjusted yours and there was no bearing to drill out, someone has already removed it & adjusted it. You definitely remember doing this, as it was a PITA, broke like 3 bits too.
But I just got it out and backed it out 3/4 of a full turn. Fuel button is next on the list. I've read 17 is a good #?
Ford Mechanic
10
Edenton, NC
That's nice looking work. [thumbzup]
Did you put down filter fabric before loading up the stone, or are you going straight over the subgrade?
Thanks! No fabric liner, straight on the ground, grass and all. I'm sure in 6 months we'll have to roll the mats back and back fill some holes due to settling. But with the mats and the top on it it shouldn't settle much. We're tamping it also to help.
Another Ahab
4,831
Alexandria, VA
Just a minor drift:
You're right I'm thinking, since you went with screenings and not just stone alone. The bluestone dust will float it all above the grade I bet. Nice work!
