Jakelc15
Hanover Pa
Replaced the shoe string type material on the Jumper port cap, with 6" of tan para cord. Used a couple of electrical connectors, ground the plastic off of them, spread them, put in the cord and crimped them with the electrical crimpers. It made for a nice clean up of something that has been an irritation since I got the truck.
Thanks for the good idea
155mm
Chief and Indian
504
Guymon, OK
Got the retrofit done today, had overcast weather until the last 2 tires. Only lost 4 mph going from 14.00/20's to 11R24.5's. The truck has a new name now though, Rock Chucker.
If you wish to delete the wheel end CTIS items, either permanent or temporary, the plug that I used is Gates G60250-0010. Its a solid plug with oring gasket. Cost less than $5 each
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Hauled this for someone. Sitting at 13'5.87" tall. Just under. Had to deflate the tires to 60psi to get em down some. JD 650G weighing around 19k.
Amer-team
55
Centralia/WA
Rooster, looks like you took a picture of my battery, but mine took out the alternator too. The good thing is that I probably won't make that same mistake again soon.
Amer-team
55
Centralia/WA
3 Way light switch woes.
Pulled the 3 way light switch. Obviously a short, but why? we went on a mission today to a parade in Quilcene. 190 round trip from my house. On the way back, the 1SG asks why my lights aren't on. I couldn't get the switch levers to move, so we kept on heading for home. Had running lights but no headlights. Pulled it when I got home and this is what I found inside.
Was it a defective switch or is there something else in the circuit that caused this overheating. Would like to rectify if you guys can think of something that needs attention.
simp5782
9,509
Mason, TN
Vibration, time, moisture, heat. Yeah and prob a few other things.
Amer-team
55
Centralia/WA
The switch was dated 2005 and the truck went through rebuild in 2006, so am hoping the vibration and heat were it. there is a lot of wire in there for a very small area. I had been smelling an electrical smell every once in awhile for some time and couldn't see anything going on. An uncle once told me if there is something going wrong and you can't find it, eventually if it is bad, you will find it. This seems to be the case.
Swamp Donkey
The Engineer
126
Gray, GA
If you look at the connector on the switch all the pins are labeled. There is a wiring diagram in the back of the -23-5 manual that'll tell you where those wires go. You could check on down the line for problems but I tend to agree that the switch just shorted internally.
I have new switches listed in the classifieds.
TwistedOaks
9
Odessa, Florida
Started this week by finishing the install of my solar system and Marinco 24v wipers (Removed the whole air driven system, including the switches).
5200 epoxy holds the four posts to the hood area, then ran two of them through the factory holes for the washer fluid (since those never worked anyway) then grommeted, and used gutter seal under the dash and under each panel.
Then finally got around to putting in some LED bars. Was really disappointed in my supplier ( I guess my Mandarin is a little rusty) since I ordered 60 inch single row 300w CREE LED and got 230w 48". Still came out good, and it is bright... I mean... REAL bright. Then added 6 40w rock-lights under the body (AKA breakdown lighting).
Then worked on the cab lighting.
Then I started teaching myself to weld (this was yesterday). (Thanks to everyone here that encouraged me to try it... And yes, it's like a hot glue gun - only melting steel!) Started by making a bracket to mount the evaporator for the AC install! Very excited about this.
Relocated the electrical system service port up under the dash, cleaned out all the old vent system piping, disconnected the defroster vents, removed the hot water system (it's florida, and the new system has optional electric heat).
Removed the Defroster/Fresh Air/Heater pull handles, epoxied the holes, sanded and Rapco'd the dash panel (then got it completely grubby again because I can't sit still for a minute). Gonna work on a way to still get the fresh air vented into the cab to work with the AC. Yes, I installed lighting under the dash and behind because I can't stand wiggling around with flashlights.
Relocated the power and starter switches out of the panel and into the old windshield washer holes (because I find myself taking the dash off so often, it's annoying to undo those two EVERY time).
Then installed the underdash evaporator and hoses. Ran the hoses for the condensor and compressor (now if I can just find a bracket :roll:). REALLY wanted to shover the evaporator up under the dash, but it fit so nice and still has a ton of foot space in this location (and is still very serviceable). Ran the electrical and control box for it, and mounted. Very happy with the controls and location.
Here's the location I'm thinking for an additional vent for driver. As it is, the vents blow so strong in the current location, I could almost do without, but I know I'm going to want it.
Ran out of time, but hoping that next week(end) I can finish the AC system up, then work on a second winch (only a little 12k) for the top of the bed to help load ... stuff...
Ford Mechanic
10
Edenton, NC
View attachment 644611View attachment 644610View attachment 644609
View attachment 644615View attachment 644612View attachment 644613View attachment 644614
So where did you get those ramps? What's the length on them?
Sent from my SM-G900V using Tapatalk
TwistedOaks
9
Odessa, Florida
titanramps.com (also one of my favorite suppliers for farm toys). They're 10'. I'm planning on putting some Zeus fittings in the deck of the tailgate to help keep things in place.
kungfu dave
Charlotte, NC
I have been wondering about securing a ramp myself. How do you plan to use the zeus fittings you mentioned. I am not familiar with them. I like the solar set up! 1 for each battery?
TwistedOaks
9
Odessa, Florida
Zeus fittings are common in racing hoods, and aviation hatches. Something like this... but I'm finding they're not made in a size that's study enough. So I might go to a ball lock dowel pin, or something similar that can go all the way through the tailgate ends (roughly 3 1/4" with the ramp ears)
The solar system is amazing. Yes, it is one to each battery. I am running 4 batteries with an isolater on each set, so I can run basic accessories (like interior lighting or dash panel/running lights which I forget - a lot), and always be able to switch over to a fully charged set for starting purposes if needed. Then I run both sets on longer hauls to give the alternator a chance to do it's job. But really, they're so efficient in the Florida sun, I'm not sure I'd know if I had an alternator beginning to fail.
simp5782
9,509
Mason, TN
Why? Something wrong with your air clutch fan? You going to upgrade the alternator also?
You save alot of horses by using these fans to keep the fan clutch off. 72k gross on 7 percent grade for 4 miles and mine never comes on. I have 2 of these fans on my 923. Plus no roar. I also have them set on a timer to cool down after shut down
Sent from my SM-G860P using Tapatalk
Amer-team
55
Centralia/WA
Got the lights working again. I had two NOS switches sitting on the shelf. Took switch number one, a nice CARC green color. Plugged it in and nothing except the light behind the shifter was lit up. So was thinking what else have I done to this truck. Got to the Troubleshooting in the manual, ran a jumper from 15 to the running lights. Didn't want to blow up the headlights if there was something else. The running lights lit up fine, so bad switch. Put on switch number two and everything worked fine. Of course switch two had dinged threads, so out with the needle files and anti seize, finally got it to go. After much contemplation, discussion, hanging upside down under the dash, and laying across the back adjuster in the door, it popped into place and works.
