6wdcummins83
- 3
- 8
- Hudson valley NY
I still want to put more on haha can never have enough. Every time I put two more on I want to put some up too now!
Make sure they will let you test using your tractor before you show up and they give you the run around.Finally used my bobtail with a a big boy trailer, just moved it around my in-laws business to a better spot where they use it for storage. Now I need to finish my CDL so I can haul on the road.
I've passed all written tests I just haven't had Time to schedule road test.
Well got home from Interop in Vegas and dove in and busted out a couple of tasks on the 925! Whew! I'm beat...
Installed an EGT probe and mounted the LED readout panel to the shift tower (still need to make an angled dash mount for it Like the one Those Military Guys offer for a cleaner look down the road)
Mounted a 24v stereo and was able to find a couple of plastic housings that worked when cut down and they screwed right into bottom lip of the dash.
Also wired in a manual backup/override light switch to go along with the Reverse gear sending unit I installed (FYI...it's the same thing as an M35 brake light switch!). I did the manual switch so it allows me to turn on the backup lights without the truck running or being in reverse or it allows me to turn off the backup lights when in reverse for those times you don't want bright lights (Example for when in "camp" and don't need to light up other people's tents lol)
View attachment 557373 View attachment 557381 View attachment 557387 View attachment 557388 View attachment 557389
Also mounted an Antenna that I will be able to use with a CB
Oh and I did pick up a couple of the diff fill plugs and got those rounded out ones replaced along with completing a full Oil & Filter service (Engine, Trans, TC, Diffs & Hyd system) Sure am glad I have an AITA membership as it saved me huge $$ at Napa for the filters & Oils! I also installed a Fumoto Drain valve in the engine oil pan to make future services less messy and easier!
I do have to say it's amazing how much faster it to do some of these things on the 925 after having learned tricks and such from doing them on the 923! lol
After patiently waiting to find a good buy on a 1" impact tool I found one that was regularly priced at 800.00 for only 125.00 name brand to boot. Talk about a deal, tested it and wow if you could only see my grin. My green beast is 23 lbs heavier but I'm sure she can handle it.
Looks all good to me; nice work.From my build thread.
Those seats are a nice custom feature.
