All pumps seem to be working. However today I took out the feed tube from the fuel tank and the lift tube has a solder joint to the fitting that screws into top of fuel tank. Air test the pickup tube and it leaks air. So it looks like that might be where the air in the lines has been coming from. Will fix that in the next few days but also going to put a 24v inline electric fuel pump just in front of the primer pump. This will help speed things up when I change the fuel filter or prime the lines. I will let you all know how it works.I have come up with a problem; Had my 923 warming up for a run the other day when it just shut down! Check fuel...that's okay. Check main fuel filter... replaced it and primed. Still won't start. Next I checked the solenoid cut off switch and it works. I even wired it open to see if by chance it was bad but that's not the problem. Engine cranks and runs some when starting fluid is sprayed so it's not getting fuel. Any ideas ??
That is NOT a small job.Changed out transmission.
I'm liking how each battery has a built-in handle.
It's almost as much fun as the shuffle to change drain pans mid stream.Just did my first oil change on the M814. Found out JUST how far oil will shoot out of the back of a NHC250 oil pan when you take the plug out.
http://www.amazon.com/Fumoto-F-106N-Engine-Drain-Valve/dp/B003T7XUE4Just did my first oil change on the M814. Found out JUST how far oil will shoot out of the back of a NHC250 oil pan when you take the plug out.
