tim292stro
40
S.F. Bay Area/California
I reduced the size of you images and posted them here - links to external sites are frowned on, you may delete the images later and forget it was posted here (then people reading the thread won't be able to see what you were talking about).
Nice truck, I like the drop-side bed, and I'm glad to see your daughter was wearing her safety gear when she was helping [thumbzup]
Assel
Germany Schwarzwald-Baar
nice ride, the new bed makes it look more like an unimog than a cucv, in my opinion...looks still better than on a mercedes or other "euro" equipment.
grüße aus dem tiefen Süden :p (greets from down south)
RobM36A2
9
The Netherlands
The bed, the engine, the horror... Nah, just kidding. Nicely done.
I prefer keeping it Original, although putting a gas engine in and running it on LPG is a loophole for the Dutch environmental zones, since mine is registered as a truck..
Groeten uit Nederland.. [thumbzup]
marchplumber
3,473
Peoria, Illinois
Ordered new voltage gauge for M1009. Old one would peg out after start up. It runs approx. 29 volts after warm up. Tried to fix old gauge, but found it it wasn't the resistor, I believe it is a 12 volt gauge. Will post pic of new gauge when installed.
joshuak
216
Slower shore, DE
Greetings, I replaced the original heater core with a Spectra Premium from the local auto parts zone. The original is going to storage, I would like to get it fixed, but this was quick and painless.
Note the bent bolt on the housing above the heater core, it bent that way when I was un threading the nut, fortunately for me I was able to straighten out and re use, after failing to remove it with the intentions of replacing. Never had that happen before.
marchplumber
3,473
Peoria, Illinois
View attachment 583498View attachment 583499
Make sure you close that air path up with the included foam..... I did NOT when I changed mine.....got only tepid warm air, nothing hot...............needless to say I did it again, this time with the foam. As ya probably already noticed the AL heater core is thinner than the brass.... ENJOY the heat this winter! =)
cucvrus
10,505
Jonestown Pennsylvania
That aluminum heater core is the best. I have my Mule and it has a metal floor and all the insulation removed from the firewall. I put one of the aluminum heater cores in and it heats much better. Could be that the original one was a bit clogged but i just replaced it when I took everything off the firewall and painted the floor. I like the bare look in lieu of the crumbling firewall insulation. Also today I changed the shift selector seal on myy M1009 Crown of Thorns. About a 15 minute job and the seal was about $2. I have a tool to do it and the tool cost me close to $90. so it was a good deal. Part of the tool removes the old seal and the other part puts the new seal in. At that time I also cleaned up the bell crank and lubed the ball and spring assembly on the frame side of the bell crank. Everything works much better now and the barn floor should stay a bit dryer. Have a good day and thank you for looking.
joshuak
216
Slower shore, DE
Hmmm, there was none in the box. I re used the foam that seals the two ports to the firewall and I was/am under the impression from reading on this thread that the Spectra Premium heater core 94553 did not require the extra foam around the sides due to the filler panels on the side, please view the first post great pics, better editing.
I may be mistaken and will not be able to report until I get my hoses hooked up. Either way thank you for the heads up, I will certainly foam up if it HOT air doesn't come out.
The end of last winter had my defroster (which needed to be on) spewing antifreeze mist on the windshield and in the cab, that was unacceptable. Not to be repeated. But, I still drove it having a perfectly good pick up truck right next to it. Funny thing this green disease :shrugs:.
marchplumber
3,473
Peoria, Illinois
Hmmm, there was none in the box. I re used the foam that seals the two ports to the firewall and I was/am under the impression from reading on this thread that the xSpectra Premium heater core 94553 did not require the extra foam around the sides due to the filler panels on the side, please view the first post great pics, better editing.
I hope that you are right! I didn't notice that the core was sized differently than mine. Let me know! It s the beauty of this thread!
Lizard Dog
Los Angeles, Calif.
Headlight wire harness upgrade. Very easy and only took an hour.
Bert
This got my attention, I hadn't heard of this upgrade, but I recently got around to replacing my dimmer switch so I have high beams for the first time.
I did some searching around to find more info, did you end up using the LMC kit like I see mentioned, or did you use/make a different schematic?
Thanks for the post!
Daniel
german m1008
1,370
Rhein-Main Area, Germany
Today i replaced the old wiper motor/pump with an new/remanufactured one.
Now the wiper blades go back from alone in its original position 8)
I have also mounted a pair of original shackles in the front.
tim292stro
40
...I did some searching around to find more info, did you end up using the LMC kit like I see mentioned, or did you use/make a different schematic?...
You can build your own, but it won't likely be cheaper than LMC - that said it could be functionally better than theirs.
My preference would be to use a 4-relay setup and fuse/drive the individual sides separately. This way if one fuse blew, you'd still have one side of headlight (high and low). I can post up a schematic if you want to "roll your own".
cucvrus
10,505
I never had any issue with the headlamps after I put some inline fuses in. And now all my exterior lighting is LED so I will have even less issues. I also have LED flashers from Truck lite so I should be good without any upgrades. now i must repair a wiper circuit on one of my trucks. it is melting the wiper fuse. i think bad ground is possible. maybe maybe not. I shall take a look see.
joshuak
216
Slower shore, DE
I am satisfied with the amount of heat coming out, I don't think I will need to disassemble to add foam. Might be a good idea anyway, but it's definitely working well as is.
T. Highway
53
S.E. WI & S.E. TN, USA - Earth
Daniel
I used the LMC kit, price was reasonable and easy to install. Just remember to buy a couple of inline fuse holders before you start the project.
Bert
