BradL84D30M1008
- 5
- 18
- Houston/TX
Your little help is awesome. My daughter new almost every tool in the box before she was four. Sockets and wrenches is how she learned about fractions.I changed out my front stabilizer bar bushings with some Moog ones I got off of Rockauto.
Getting them off was pretty straightforward except for the top bolt on the passenger side. I ended up using a wobble joint and a wobble one inch extension on the socket so it would fit behind the brake lines.
The future little helper put the grease on the inside of the new bushings and smeared it around.
View attachment 677122View attachment 677123
I had to take a file to the new brackets that came with it because they very edge of the screw threads were catching when I put it on. A few swipes on each side and it was fine. Everything looks good and bolts up nice.
View attachment 677124View attachment 677125
When I was under there, I saw the long steering arm bent.The previous owner had it aligned with the bent bar. It drives good and true, so I guess I'll just leave it for now. Money doesn't grow on trees.
 As a rule the hinge pins are fine. It is the bronze bushings that go bad. I know I used to buy them in a pack of 10 from GM. They are not bad to replace. If the hinge itself has excessive wear it will require replacement also. I have found the hinges to be in abundance. As far as the shaky vibrating mirror. I would be willing to bet the brace/reinforcement is loose or missing. Also the riv-nuts are not the best at this date. They are nothing more then tin when new. But the brace is most important to prevent the vibration and provide strength. Also check the long screw under the wing vent that helps retain strength in the door area by pulling the inner and out panel together and tight. I hope that helps. Have a great day.Replaced both door strikers today, was a big improvement in closing both doors.....and will replace door hinge pins next.
Also replaced passenger mirror today......plastic mounting gasket under the original mirror had just about disintegrated and so mirror was vibrating quite a bit.
View attachment 677196View attachment 677198
Finally got around to mounting my MRAP seats in the M1008
I now have a complete bench seat for sale with a new lower cover included but not installed. This includes the plastic covers etc. PM me if interested
Yeah, the mirror riv-nuts from GM are garbage. I replaced mine with some quality aluminum ones and it totally stopped my mirrors from vibrating.As a rule the hinge pins are fine. It is the bronze bushings that go bad. I know I used to buy them in a pack of 10 from GM. They are not bad to replace. If the hinge itself has excessive wear it will require replacement also. I have found the hinges to be in abundance. As far as the shaky vibrating mirror. I would be willing to bet the brace/reinforcement is loose or missing. Also the riv-nuts are not the best at this date. They are nothing more then tin when new. But the brace is most important to prevent the vibration and provide strength. Also check the long screw under the wing vent that helps retain strength in the door area by pulling the inner and out panel together and tight. I hope that helps. Have a great day.
Turned down yet another offer from someone to buy my truck while I was at gas station.
If I had a dollar everytime someone wanted to buy my truck......I could buy another truck.
Who did you get the seals from. I need to do mine, but don't want to but junk.Got all the new door seals in on the cab. This is a no brainer on all these trucks.
Unless it's a ridiculous amount......no way in he//.Are you going to consider the offer next time?!
That's kind of what I meant but I didn't say so clearly.Unless it's a ridiculous amount......no way in he//.
Is it all mechanical fit, or is there a sealant you got to use?Got all the new door seals in on the cab. This is a no brainer on all these trucks.
12kThat's kind of what I meant but I didn't say so clearly.
Have you got a threshold figure in mind (that says "ridiculous"), so if someone offers it you make the deal right then-and-there?
