rustystud
3,394
Woodinville, Washington
In this case, it was moving that front battery from it's stock location back to reside parallel to the rear battery.
The slope of the hood clears the rear battery by inches but was nearly in contact with the front battery terminal.
I bought the truck in Oregon and drove it home to Wyoming.
But I only started wheeling it offroad recently.
The additional flex created by 33 inch tires probably contributed.
It wasn't like I was railing along at speed.
I was creeping in low range about 3 mph.
I should know better.
It all looked so nice and the battery tray had been done along with an LMC headlight box.. I made the mistake of getting complacent and trusting someone elses work.
My fault.
Lucky it is just a few holes on the inner sheet metal of the hood and not through the hood or worse.
I am a dummy.
No, your not dumb. In fact your pretty smart to look for the problem before it became a "REALLY" big problem. A lot of people would just let it slid thinking it was nothing.
One of my biggest "bugaboos" is electrical fires. Having had a big one in my past. So I'm always smelling the vehicle which drives my family nuts. I will ask "do you smell that ? " and they usually say "No Dad, there's nothing there. It's your imagination" .
computer54
Nashville,TN
I look for fuel on the motor and other places that fuel can get to and heat well get to it. Found some fuel leaks and have fixed them and now looking at other places the they have fixed before I got the truck.
rustystud
3,394
That is also a very good thing to always check. I had a diesel tractor that caught fire due to a small fuel leak on the exhaust manifold. Thankfully we where able to put out the fire. Just smothered it with dirt. Scared the crap out of us though !
We never even knew there was a leak it was so small.
Rutjes
272
Amersfoort, The Netherlands
I've had 3 fires before. First one was my mom's Daihatsu Cuore which I was driving after an oil leak fix. Caught fire at the cooling fan connector.
Second was at the window electric window buttons on my work's Iveco Daily. I guess it got wet in the rain (I maneuver trailers around a lot, hanging out the window/door for better visibility) causing a short and someone had replaced the 3A fuse with a 10A fuse before...
Third was with he Daily as well, some wiring got loose and shorted. I was dropping of a trailer for the next job and I noticed smoke. Opened the hood and saw flames down in the engine compartment. Called fire department. Got the fire extinguished before they arrived tho, found a bottle of Glassex that I poured over it. They checked with heat cameras too make sure it was out.
Funny thing is, there is a fire station like 0.15 miles away, but they had to come from down town...
Now every time I smell something (usually a cigarette still burning in the ashtray) I look under the hood haha.
One of the first things I got for my CUCV was a fire extinguisher. All other vehicles can burn down to the ground for all I care, but not my truck!
And to stay on-topic, I pulled a shipping container over pavement so I could finish my job, settings up market stalls.
Had to use 4Lo to get it to budge... :grin:
911joeblow
72
Utah
I have been on fire in a racecar, not cool. Fire system and good safety equipment saved me as well as practicing egress from the car many many times just in case. I don't own a vehicle with combustibles in it that does not have at least a halon fire extinguisher in it. Overkill perhapts but I don't want to be on fire again. ��
Another Ahab
4,982
Alexandria, VA
Burn injuries are horrible, not that any injury isn't.
A buddy of mine from childhood messing with a train sustained third-degree burns over 75% of his body when we were youngsters.
Statistically he "should" have died.
He recovered, and he's fine now, does house painting and paper-hanging, married and two sons. He's all good.
But he did tell me that dying is a kind of mercy for burn victims. Said that the pain from the nerve regeneration (if you make it) is like nothing you'd be able to believe. My buddy, Chease. God bless him, a good man (a little crazy, but good). Amen
sneekyeye
142
ALABAMA
Well I attempted and succeeded in putting in a rear axle hub oil seal on the1028. However I seemed to have bent the seal portion and ruined my new seal when I installed it. I put probably thirty miles on it today and came home to oil slung all over my rear rotor and up and down the inside of the tire. Tomorrow's chore is to find a big seal installer and a new seal and put a second one on. Hopefully without goobering it up this time.
DREDnot
643
Avondale , AZ
Mounted my bridge plate. Thanks rocket990.
Added some bumper numbers
The FL-NG-X had been painted over and was on the original CARC green paint.
The VIN search only revealed a UIC of W1Q9AA which so far is a dead end. So I just went with Non Tactical Vehicle #3
cucvrus
10,507
Jonestown Pennsylvania
Big seal installer is an easy short piece of 2 X 4 layed flat and hit to drive seal in. 2 x 6 will work also. Walnut, pine, fir, or oak. Anything that lays flat.
sneekyeye
142
ALABAMA
So I made a seal installer out of a piece of 1x4 maybe maple and a scrap of 2x6 with some all thread. I just put it on and tightened it down and it pulled it on in this time. Hopefully its in there good and I don't have any more leak on that side. I'm waiting on the axle shaft rtv to dry before I go roll around the neighborhood to test it.
Bighorn
N/A
Reinstalled the glow plug resistor pack (Thanks, CUCVRUS) so my system is stock.
Truck starts even better.
Like instantly firing instead of turning over twice.
Not a huge difference.. but there is a difference.
Replaced the vacuum transducer on the injection pump.
Had found one on ebay that was new old stock and cheap.
Totally changed how my turbo 400 shifts.
Even though the old transducer seemed to be functioning correctly according to my vacuum gauge, my shifts were high.
I couldn't adjust it down to where I wanted it to be.
The new part got me back to a range where I can actually get what I want.
So even though the vacuum gauge read number in line with information on this website, there must be more to the function of this part that was a little out of spec with the old one.
Smooth as can be now and still firm.
Shift points are much lower.
Ac Delco and GM # 14057219
papa8856
Spring Hill Fl
Changed Front and rear Differential oil
Changed Transmission filter and fluid
Drained transfer case and refilled
4 new shocks installed
Changed glow plug relay
Changed fast idle actuator
And Still troubleshooting my right front Directional ( inop)
cucvrus
10,507
Check the bulb socket. You should have a small sliver of steel protruding into the socket that serves as a ground. If that is missing go to NAPA and get another socket. I have the Part Number if you need it. Hope that helps. Have a great day.Part number LS6461 cost is 8.39ea. From NAPA
papa8856
Spring Hill Fl
Thank you for your input. I changed it last night I have 12 volts at both silver prongs at the bottom of the socket. At the same time I don't know if this is correct or not. I have to chase some wires tonight. I will check the ground again.
