Rob,
Maybe start a new thread? Kinda sounds like the controller card lost it’s mind.
Worked on a friends 1008. He is the kind of person that can destroy an anvil with a cotton ball. His rig has had drivers side camber issues for a long time, most likely from an encounter with a stump. A couple years ago he replaced the lower kingpin bearing, the seal, upper kingpin, bushing, seal and spring on both sides. This made things a whole lot better, but the drivers side still had a noticeable amount of negative camber. Finally got around to installing a tapered spindle shim to correct it. Kind of a strange fix, the shims are some sort of glass impregnated plastic. Installed a 7/8 of a degree shim. Now both sides are right around +.5 degree. We’ll see how it holds up.
