SDJunkMan
11
Rapid City/SD
Thanks for the reply. I am not sure how to post pics.
The pins I am referring to are the 2 pins that attach the plow assembly to the plow frame on the truck (at the end of the A frame). I am running an old Meyers plow.
I have tried all kinds of pins, actual Myers pins, hitch pins from the farm supply store, and pins for reciever hitches, plus a variety is spring clips on the pins, but still manage to lose them quite often. There probably isn't a better option, but I figured I would ask.
I was able to heat up the hinge bar and straighten it out enough to get it back on the truck last night, but the metal is stretched and probably won't last long. Hopefully long enough to finish my parking lot and driveway.
I have ordered a replacement hinge bar and will cut the old one off and weld the new one on when it arrives.
cucvrus
10,505
Jonestown Pennsylvania
I would say a cotter pin. Or perhaps a roll pin. But you must take up the slop. That gets a beating back and forth if you don't keep it semi tight. If it is out of square it could be stressing the pins and shearing them easily. Use steel or washers to get it tight. Then grease the crap out of the large pin and lock it in place with a bolt , pin, cotter pin, or weld a washer on the end and burn it off later. In the heat of battle what ever works and keeps you going is a great fix. No right or wrong. Just keep going. Good Luck. Be Safe. Happy Holidays.
D6T
536
Vermont
My CUCV plow is a Fisher Speedcaster, but I believe I know the pins you speak of...
Looking here: https://www.fisherplows.com/parts-service/parts-list/poster/mc-series-a-frame-components/
...near where the number 178 is seen, there are three holes on each side of the A-Frame. You want the spring-loaded pins that go in there, correct?
Since yours is a Meyer, let's take a peek there...
http://www.equipmentspecialistsinc.com/cms-display/meyer_parts_classic_st.html
...possibly parts 17 and 18 in that diagram?
Chaski
56
Burney/CA
https://www.mcmaster.com/pins
McMaster Carr has some neat looking options.
MarcusOReallyus
820
Virginia
Well, we have a "Forum Tips and Tricks" section where you should be able to find a post on how to do that, but unfortunately, it's been overrun by a bad case of the stupids, so it's completely useless. (I know there's a post in there on that topic, but I couldn't find it for you, and I originally posted it!)
So here's a quick version:
First of all, make sure your profile settings for the Editor are set to WYSIWYG (What You See Is What You Get).
Go to your profile (Top of the page), and click on "Settings".
Now look for "General Settings" on the left (scroll down as needed)
Now look for the "Editor" section (scroll down as needed) and make sure the radio button is set for WYSISYG.
Now you are ready to post piktoors, lahk us'n ex spurts! :mrgreen:
So, once that is done, when you create a post (or reply to one), you'll see the editing bar at the top of your reply window. See that Insert Image button there? Mash that puppy!
This will pop up a dialog box. It usually comes up (for me, at least) thinking I want to link to a URL. Nah, I wanna upload from my computer, so I'll click that tab.
That will change it to look like this guy. Hit the "Browse" button (blue arrow). Once you have browsed to your picture, select it, and hit the "Upload Files" text there (yellow box) that should look like a button, but doesn't, because somebody doesn't know how to build an interface properly.
Bingo. There you have it! :beer:
Now, all y'all of the rest of you, bookmark this post so you can just point people to it. (Click the little number on the post to the top right and copy that URL. It will always take you to this exact post, not just this thread.)
Another Ahab
4,957
Alexandria, VA
:jumpin::funny:
dougco1
708
Cooperstown NY
Installed an oil pan heater on my P400 engine.
Your going to love it.
I installed one on my 30 year old Kubota G6200 diesel garden tractor. They work great. Its parked out-side 24/7 and all I do is plug it in about 1/2 hour before I need it and she fires right up.
cucvrus
10,505
A Kubota should fire up at -25. Mine always did. Try starting it without that thing. Kubota's are made to take on the world. I removed the in line coolant heater because it was just there. The prongs on the heater element were corroded right off. One time it was cold and fired right up. I went to coil the cord up and the cord fell from the engine. It hadn't been working in a long time. It was a pcycological thing. I eliminated it and actually glow it the 60 - 90 seconds. That little glow plug indicator does glow RED HOT. Just teasing. Do as you must. I have a Yanmar diesel engine on my log splitter that I pull start. Today is one of them days. Happy Holidays.
Miah
29
Kansas City-ish, MO
now that we're back.
Installed updated gp temp sensor & pigtail yesterday & managed to get it titled & tagged this afternoon so i'm officially street legal.
cucvrus
10,505
When is the last time it got to -25 below in Jonestown?
I travel to Sullivan/Bradford county PA all the time. We have a manual Kubota B7100 up there and it gets quite cold in winter. Exact time and date i don't know. But I used the tractor in Lopez PA to clear snow and get wood and it was -30. I had the battery inside over night and it fired the tractor after glowing the plugs about 90 seconds. Rare ocasion but it happened. If kept inside out of the wind it always seems to help with most vehicles. Even facing a wall with the front end seems to help. But with the CUCV's coolant heater was all I ever used and very seldom. Happy Holidays. Don't make me get the grinch out after you. https://www.citizensvoice.com/news/...-norm-for-sullivan-county-community-1.1826413
TechnoWeenie
1,815
Nova Laboratories, WA
I only needed 12 Bosch glow plugs to replace the SWELLmans that were 35 yrs old. Damn tabs kept breaking.. known issue apparently.
Pulled the dash apart, painted the back of the cluster gloss white, replaced with LEDs except GEN bulbs... Bought a 2 pack of Bosch 194s... 1 of which was DOA.... ~SIGH~. It's a bulb.. how hard is it to not screw up? Apparently Bosch isn't the company it used to be.
Upgraded factory battery cables, bypassed GP resistor....then forgot I needed to replace the GP relay too.... So, truck wouldn't start.... gotta tackle that and add a manual GP switch today...
