What have you done to your HMMWV today/lately
TNDRIVER
579
Cleveland,TN
Feltz shipped me a new wheel before I even knew it was coming. Excellent customer service in my opinion. Hopefully this will fix my issue. I need another set for my M1165 and I will definitely get it from Feltz. I need to install the floor mats in my M1123 today but I can’t seem to be able to walk away from morning coffee! Plug for my BUNN automatic coffee maker! lol 12 years old and still amazing… little off topic but maybe it will help someone else.
A coffee maker is no better than what you put in it, right? BLACK RIFLE!
Maxjeep1
1,930
Las Vegas Nevada
I got wheel out and I didn’t expect to see this.. I don’t know how it’s supposed to line up. I think the notch in the second pic is for the valve stem. I had to flip tire and it shifted inside the tire. IMG_2131.jpegimage.jpg
Mainsail
1,808
Puget Sound, WA
Took the cat off for ... servicing. No major drama but the bent wrench was necessary for at least one of the flange bolts.
Spent two hours trying to get the forward heat shield [#11] back on without luck. I should have taken a picture before I removed it and the manual only tells you to put it on with two clamps [#12].
I tried removing the transmission cross member and the side bracket to the frame to make room, but I can't see how in the world it goes on. Any photos or suggestions welcome!
Jinx
Buy me a Coke
753
203
Gainesville, FL
Today I did the first oil change to my M1114. Super easy! I love these trucks are basically old school technology. I also replaced the fuel gauge and aired the tires. Still need to Dremel the paddle lock left on the anti theft device located under the dash. It's a Master Lock so it may never come off. LOL
thompsoncustom
120
iowa
Just a little sound proofing today added closed cell foam between the hood and the window frame made more of a difference than I was expecting, also ordered more Kilmat 50sq/ft this time instead of 25 tho I'm thinking now I should mat the whole underside of the hood and then put CCF over it so I'll probably need more later.
Bulldogger
776
Quantico VA
Please share a few pictures. Sounds interesting.
BDGR
thompsoncustom
120
iowa
BDGR
here's ya go, if I had to do it again I would have taken each layer of aluminum off and than taken a new razor blade and trimmed the whole thing so it looked like 1 solid peice but with the top aluminum layer off you don't see it with the hood down.
here is a spot that pushes out a little with the hood locked down.
HUNvee
257
Hungary
Bulldogger
776
Quantico VA
Many thanks. Where did you order it? Got a link?
BDGR
Maxjeep1
1,930
Las Vegas Nevada
Also I swapped wheel with the replacement that Feltz sent me. It took 14oz to balance and it rides smooth! I had to take it to Ted Weins to get it balanced because it was so heavy.. can’t say enough good things about Feltz….
Maxjeep1
1,930
Las Vegas Nevada
Hmm, what about the 3.5 ton scissor jack, have you had issues with that? Asking because I just bought one.
I haven’t tried a scissor jack. I have an aluminum jack that has a rubber pad on it and bolt tears up the rubber pad. I have a different floor jack and the pin that holds the cup to the jack sheared off and it shot out. I think Bogert will be better.
