What have you done to your HMMWV today/lately
TOBASH
3,978
Brooklyn, NY
I want to JUNK my rig... Thing has me so pissed off... The issues I am finding is crazy...
So doing the "check the spindle nuts" (don't judge is was consensual) I found 1) drivers front the bolt holding wasn't tight, missing the sealing washer on the fill plug, and RTV in the bearings.2) Drivers rear has issue before I check the nut with missing bolts on the CV axle and no clamps on the CV boots. 3) Passenger front the tie rod end where sloppy loose. The nuts were only finger tight but did have the cotter pins installed. There was a ton of slop. All plugs were loose as well of the nut cover plate. And RTV everywhere... While working on the passenger front I spot a leak on the floor. Fuel pump... Off to order pump. Back to the passenger rear. All is looking good then I spot the bottom ball joint zerk fitting is broken off.... This isn't going to be easy to remove... Then I touched the nut ... It is loose but the tabs are bent in. I can move the spindle about 1/4" in and out. Of course I ordered the fuel pump and has already been shipped. Have to order the locking washers... should have waited to place the order for the pump... Pissed at this.
Now this ins't by first rodeo when it comes to Mil surplus vheicles... and I know how they can be. But this one is taking the cake.
How much if a pain is it to set the preload of the hub while it's on the truck? GRRRR... Can you take the hub out without removing the CV axe from the diff? If not I will need some nordlocks... at least I believe I can get them locally...
What tool are people useing to seprate the ball joints from the hub? Will a good knock of a hammer work?
At least I have a face of the Mechanics who have worked on my truck... The bottom picture is MY truck... Hope they found something other than turning wrenches after the Corps :wreckerman893:
So you found the loose hub nut BEFORE you lost your wheel… and you’re upset that you are all in one piece and not injured?
Mogman
10,601
Papalote, TX
Now just like lug nuts I replace all the half shaft bolts and Nord lock washers on every Humvee I get, it is a good idea to inspect the flange threads as who knows what they have been through.
spankybear
981
WA
No... I need a new star lock washer and I JUST place an order BEFORE I found the loose nut. I am a cheap bastard and hate to pay shipping twice.
They also had the nut on backwards and there was a huge burr on the threads... the nut wasn't going to seat. Also having a heck of the time trying to get the broken zerk out.
spankybear
981
WA
I was thinking. Yes I know we are not supposed to do that but, What is the reason not to reuse your star washer. I would assume that you would not want to bent the same tabs more than once. Since the nut wasn't tight and upside down I went and installed and torque the nut. I wanted to see if the groves line up with the bent/used tangs. They did not line up with the used/bent tangs. So there are "fresh" tangs to use. I know the correct thing to do is use a new star washer but if you are not using the same tangs why no reused the washer?
20,804
There are "star washers" and there are "tang washers".
Definitely different animals.
Star washers shouldn't be reused. People do it all the time though, so go about it your way?
spankybear
981
WA
True but in the context of the spindle nut I would think people would know what washer I am talking about. I could call it what the parts TM says, Washer, key and I am sure people would be all like Whisky Tango Foxtrout
20,804
Yes sir. You are right.
Mogman
10,601
Papalote, TX
I would say if they are the correct type (uses two tabs) and it happens to line up with unused tabs, then I would reuse them, I would look very close to the used tabs and if I thought they were week I would go ahead and break them off so they would not "fall" off into the bearings.
Of course I would not do that for a customer or a vehicle that I planned on selling , only a personal vehicle.
spankybear
981
WA
Thanks... Yes my nuts are the two tab style and I didn't see any cracks in the washer. I do like the idea of breaking off the tabs... I may save any old ones and break off the used tabs. May get you by in a pinch. assuming you use them on a different hub.
Anyway I did take the truck out for a test drive and wow what a differences tightening up the tie rod ends and wheel hub bearing. Truck feels good to drive... better than before. I also replaced the turbo and seems to run better. Thought I think that is just in my mind.
cahilj
160
33
KS
I got the storage box in. The entire thing has 4 bolts to take out and it comes right out. It worked out better than I thought. Now my wife has a blanket storage spot.
I also finished up the VAA for now. I ended up gutting and rewiring it. I added a 12v converter and some SAE jacks for future use. I made the field wire terminals into 12 and 24v test points just because. I also added a Hella map light I've had kicking around for a while.
Finished up the GMRS antenna and wires.
Also added a few more CWI stickers. I'm taking entries for the pool on when anyone thinks someone will try to get into the grenades :LOL:
kromby
35
13
MA
Been leaking diesel like mad for over a year out of the torque converter dust cover drain, time for an injection pump change
It was hard to see in the truck but sure enough. I found 7 hose clamps 9 1/4-20 bolts and a bunch of junk in the valley even after cleaning it up.
Strangely enough, the drain port was not blocked and the paint under the rusty mess was intact for the most part
Runs like a champ now but it could have something to do with the fact I didnt realize my throttle cable was completely un-adjusted and I only had about 1/2 throw of the throttle linkage.
I got the bigger injection pump (planning on possibly adding some air) so installed a pyrometer for good measure.
Mogman
10,601
Papalote, TX
Glad to see someone plugging those holes, I actually have the factory intake port caps for the heads, they have very small slits in them so you can turn the motor over, :)
Mogman
10,601
Papalote, TX
I picked up a shelter that still has the monster rack on the front so I can mount my MEP831A and some other stuff above the cab, it also matches the color of the future DuraVee II since the DuraVee I is getting a helmet top and will no longer be able to accommodate a shelter.
I told Pam if I got another one (this is #4) I would give her one to use for animal feed, I said it so I guess I must make it so.... :eek:
Diggy Dog enjoyed running around the GP yard and checking out their yard dog and cat.
m715mike
3,923
Montgomery, Texas
Spent the morning getting the HMMWV ready for a Memorial Day event tomorrow.
A big thank you goes out to @Kvrazelm923 for coming out and actually doing most of the work.
On the front right hub, we replaced the input shaft seal and the spindle seal.
Changed the engine oil and oil in both differentials.
Hit all the grease fittings.
Gutschken
Lubbock, Texas
Done a litte bit since last update:
Removed old tires & runflats, replaced with unused (5 year old) tires.
Installed centramatics.
Removed all lights, prepped & painted exterior as well as lighting assemblies.
Removed floor lining & scrubbed Michigan out of the floor area. Painted floor area while I had it clean & exposed.
Installed soft doors, soft cover, soft cargo cover.
Got insurance.
Went to DMV and had a good experience with a clerk who had never done a humvee before *but* was very interested in figuring it out! Walked out with temporary plates!
Installed lighted rear plate mount, installed plates.
Went for my first drive longer than 1/2 mile. :clinto: It was wonderful! Drives smoothly, screams the banshee-scream-of-doom when the cooling fan kicks in, reaches 70 without difficulty. Had one brief moment where lost power & wouldn't shift to 4th. Pulled over, shut it down, restarted, worked like a dream - going to keep my eye on that.
Before/current pictures attached. Thanks again for all the expertise on this forum!
