What have you done to your HMMWV today/lately
Dock Rocker
73
Jackson ms
Can you help me with what brackets you needed to install the bumper? I really want one but I have no idea what brackets to get to mount it. The bumper is easy to get.
5,171
I added an air lift bumper. Still need to paint it though. And get whatever parts are needed to make my pioneer tool rack mount up again.
I want a airlift bumper for mine. Thinking about just fabbing one honestly. Do you happen to know the tube measurements to yours? (Length, width, height, thickness)
KansasBobcat
9
San Antonio, TX
The bumpers are fairly easy to find. I got mine before latest auction and the brackets were a challenge even then. I got some parts on ebay but had to go to Kascar for some. Be sure and order by part number. Brackets cost at least twice what bumper cost!
whistlepig
big branch tn
Thanks Kansasbobcat , I've probably got 6 hours fab time in just the bumper. Not counting the trip to the local sheriffs dept. to measure an actual factory bumper. Ahab, Patracy is correct on the tag cover.
Another Ahab
4,942
Alexandria, VA
I think I would be nervous having that much weight on four 1/2" or even 5/8" bolts.
I know what you mean Dr Goldberg MD; it seems kind of "light". And there are a lot of variables for sure, but the chart below indicates (on an average I'm supposing), that the shear strength of a 1/2" bolt (Grade 2) is:
- 1470 lbs
So 4x that is 5,880 lbs (close to 3 tons). I'm thinking that bumper is pretty secure with that arrangement. But I'm for sure no structural engineer. So maybe somebody more qualified can chime in:
NH
I know what you mean Dr Goldberg MD; it seems kind of "light". And there are a lot of variables for sure, but the chart below indicates (on an average I'm supposing), that the shear strength of a 1/2" bolt is:
- 1470 lbs
That's funny. I was literally just reading the same chart after searching 'grade 8 bolt shear strength'. Now, I'm sure it's not going anywhere. I just look at it and compare to twenty 1/2" bolts going through mine.
Retiredwarhorses
4,606
Brentwood, Calif
The inner brackets are very cheap for a pair, the 2 outer while a little for expensive are also cheap...you can use right or lefts...makes no diff, the bracket can be flipped. The inners are the same, the shims can be just washers.
so maybe 125.00 total for all 4 brackets...
Dock Rocker
73
Jackson ms
You don't happen to have any laying around the shop you would part with do you?
