What have you done to your JEEP today
Maverick1701
208
Lubbock, TX
Well I passed a big milestone today.
The PTO is assembled and installed into the jeep and does PTO things correctly. The output shaft spins when it should and doesn't spin when it shouldn't.
I had about 2hrs of free time today before work so I rushed out to the shop to try and get the PTO assembled and installed on the jeep.
First step was to cut the chain to length. This went easily enough as I kept a chain cutter from my motorcycle days. Once cut to length, I had to thread the chain onto the sprockets and instert the new master link.
Then I installed the new oil seal on the PTO output shaft. It was simply pushing it over the input shaft into its home with a little RTV to keep it secure.
After that was compleete, I uninstalled the circular cover which covers the transfer case opening (just give bolts so it was super easy).
Then came the mounting PTO.
I kept the housing split for ease of installation (plus I didn't want to drop a mounting screw into the closed housing). The first time I tried to install it, I found two issues. One, the PTO housing interefered with my E-brake rod. Two, I wasn't able to get the PTO mechanism inside the transfer case hole due to the bend in the shift lever. (I couldn't move the unit up enough to clear the lip of the trasnfer case). I removed the hand brake rod and shift lever then got it in place.
Once I installed the mounting bolts (with locktite) I attached the other half of the housing and got it all bolted down. Then I (re)installed the shifter lever and top cover plates. Currently up to 4 shift levers in the jeep. If I ever spend the $$$ for an OD, I can increase that count to 5.
I may find another solution for the e-brake or I may just leave it off entirely if it's going to be a PITA just to have a handbrake I'll never use.
I still need to fill the PTO with lubricant. I'm thinking I may just use JD corn-head grease as it's thicker than normal oil but less viscious than true grease and does flow/settle around the housing.
Next step is to get some THICK angle iron cut and drilled for winch mounting. That might be...interesting....as I only have a hacksaw for cutting, but I have time and muscles, right?
One future issue I can see, is the routing of the winch driveshaft. The PO installed a DIY/home-brew exhaust system on the jeep which blocks the drive-shaft access area.
But that's a problem for future me. Winch first then I'll fix the exhaust with the correct setup.
JEB
165
Colbert, WA
It'd been awhile since I've dome an update...not too surprising since the Jeep has been hibernating with my other toys in the back of the garage for the winter.
Dave, the guy who restored it, came over to check on the fuel gauge reading.
To make a longish story mercifully short, there was a bad ground on the gauge.
But since so had ordered a new sending unit, we installed that ad well.
I'm still not convinced it is 100%... with the tank nearly gull, it still reads about half, but that was with the engine off.
Still, it reading at least a half tank is better than it was...reading about 1/4 pretty much all the time...even when empty.
None of the gauges seem terribly accurate, I've been told "They all do that".
In other news...
My photo and description of some of the events we've supported was published in History in Motion the magazine of the MVPA in their member photo pages. I submitted the information in late 2023, and had pretty much given up on it being published. Well, better late than never
Maverick1701
208
Lubbock, TX
With the PTO done I've been working on getting the winch mounted.
It's been time-consuming since I don't have a way to cut metal at home.
So I've been begging the airfield maintenance guys at my work to get some time on their bandsaw.
I cut some thick angle iron down to size 12in sections. I also cut some flat-steel into triangles which will be used for gussets/supports once I get everything mounted. Once I figured out my hole size/locations/etc I used my super high-tech drill press (battery powered hand-held drill and my muscles) to knock-out the holes. Everything lines up perfectly and the mounts are in. However, I have a few more steps before I can mount the winch.
I removed the rear winch mount from the winch to see how everything lines-up and it's actually too long (the holes in the mount line-up with the inner bend-area of the angle iron (See pics). So if I use these mounts without modifying them I won't be able to bolt anything...it'll be welding which is fine. I'll need to do some cutting length-wise down the mounts. Then the factory mounts on the winch should drop into place and I can have someone zap them with a welder....and done.
I considered modifying the mounts but given the length of the winch it's not possible. I would need to shorten the mounts by .5in on each side and it would interfere with the winch body.
Mounts installed with grade 8 bolts
Top view:
The mounts with the winch mount to see where the bolt-holes fall
My super high-tech drill press:
I'll need to cut along this line for the factory winch mounts to just drop onto my angle-iron mounts....then I can have it welded it in place
DeetFreek
369
New Sharon IA
Had a slight "scare" moment over the weekend with the '53. On the drive to an event early Saturday morning, the engine began losing power and had a wicked miss. Limped it to the event location without it becoming worse. Later in the day, I got a chance to poke around the engine and determined at a minimum, the #2 cylinder was dead. Took the back roads home and pulled the plugs to see if any were fouled to no avail. Began to run through troubleshooting scenarios and decided to run a compression check. Three of four cylinders were around 110 psi. The other, barely 40 psi. Which cylinder you ask? #2 it was!
Next step, pull the valve cover and inspect the upper valvetrain. What you see in the pictures is exactly how I found it. The jam nut on the adjuster of the #2 intake valve had spun itself completely off! This is where I was extremely lucky by not having a catastrophic failure by bending the push rod or tweaking the rocker arm. Reset the valve, double-check the clearance, reassemble everything, and it's back on the road!
