What is this green resister looking thing?
HmmwvTim
95
IL
I was looking in the dash and I saw that this looked loose. What is this? What does it do? Is it repairable or should I buy a new one? I liiked through the electronics section from my TM and couldn’t find it. what is the part number if I need to replace it. One of its wires is coded 399.
HmmwvTim
95
IL
It is a resistor for the low blower setting
Thanks for telling me. Now that I know what it is, it took me 3 seconds to find the PN. 12338468
since my lower blower still works with no issue, I will leave it. I may paint some resin on it to keep it solid, unless someone tells me otherwise.
Guyfang
22,191
Burgkunstadt, Germany
I simply can not stop my self. A resister?
What model do you have. I will look it up if one of the Obi Wan's doesn't show up.
Heater Fan Switch Low Speed Resister.
Mogman
8,296
Papalote, TX
Should not hurt to coat the ends, keep wires away they get pretty hot.
HmmwvTim
95
IL
Not the best job but saves me 60$.
i have parchment paper(for cooking) under so I can limit spill. it doesnt stick. I used shop paper towel to get the excess dripping to the bottom.
this seems to do the job.
Thanks for your help.
Response time is quick and helpful on this site.
