What is This?
M813rc
3,879
Near Austin, Texas
There was another thread on this video a few months ago, I haven't a clue what the title was. As I recall, it was not military. Cool thing to have though. Not many frozen rivers around here to play on.... :(
Cheers
maddawg308
821
Appomattox, VA
That thing looks pretty cool - takes a Russian with balls as big as pumpkins to test drive a 4x4 on a thin ice layer like that in the middle of winter. Bet he has lots of axle maintenance to do now!
Another Ahab
4,905
Alexandria, VA
I'd have to take a second look at the video:
- but the dash on that thing might have been designed with enough room underneath for just that very reason…
ok,ok; now where's that remote?
EMD567
Driver for the Ga Mafia
Aiken SC
My translate program says it is a "makeshift jeep". It looks like a bobcat that floats with big tires.
USSR
316
USSR
Technical characteristics: Dry weight - 1050 kg
Wheelbase - 1780 mm
Width - 2470 mm Height - 2100 mm
Tires 1300 x 620 - 21 "
The width of the inner disk mounting surface - 500 mm
Weight of the wheel assembly - 75 kg ( without the hub bearings)
The actual tire width - 620 mm
Cabin width - 1150 mm
Bed length - 2100 mm
Cargo Volume ( under the bed ) - 600 l
Engine - Turbodiesel Kubota V1505-T Power - 44 hp ( limiter ) Torque - 118 Nm
Engine weight - about 120 kg
Generator - 90 A Battery - three battery 40 A / h Light - two xenon dipped and main beam of 100 W each.
Transmission - VAZ 2110
Drive - 3.9 Transfer to the differential rotation mechanism - chain 16B -1 , 25.4 mm pitch Attitude - 27/12 = 2.25
Differential - Kamaz interaxal . modified Drive - chain 16B -1 , 25.4 mm pitch Attitude - 40/12 = 3.33
The main fuel tank - 130 liters Supply tank - 0.5 liters
Fuel consumption average - 2 liters per hour
USSR
316
USSR
Terrain vehicle "Predator"
Created by "MEG West" on the basis of GAZ -66 used by the military, was created by skilled craftsmen tractor "Predator", able to swim as well as move the virgin snow or swamps. The machine is equipped with wheels with a low-pressure tires and propeller blades to move through the water.
