What kind of life can you get out of a 923 with a NHC250?
maddeuce360
pittsburgh/pa
Im looking at getting a 923a1 , i was wondering if i use it for hauling. what kind of life or mileage should i get out of it. If i do regular P.M's , is it the same as any other truck? thank you
juanprado
2,898
Metairie/La (N'awlins)
In their day, these engines would go the distance and some. Would not be unusual that they got 200-300k.
Some are still in use in older pumps and generators. A few still work old railroad locomotives from what I understand. Also were used in farm equipment and I suspect many are still doing duty in the fields.
Be good to her and she will be loyal. :driver:
maddeuce360
pittsburgh/pa
thanks for the replies, 200-300k would be far more than i expected.
As for what type of hauling , nothing more than what a 923 would be rated for. ( i assume its rated on the low side ? ) Mostly all highway hauling just general items, stone, dirt , scrap. things you would do in a tiny truck. I also would like to pull a trailer from time to time or if i get really frisky another truck bought at auction.:D
VPed
294
Clint, TX
Dirt and other trucks...been there, done that. BEWARE!!! Getting the first one sure makes it easy to go get more. That 855 cubic inches can sure drag stuff well. Serious off-the-line grunt compared to the A2s.
simp5782
Feo, Fuerte y Formal
9,355
Mason, TN
What the government "rated" it at is so that some 18 to 22yr old wouldn't go "let's see if we can get 30 tons in the back of it, It says it will hold that much!" . The cummins is reliable and not too needy. I trust mine to go to California and back right now. I have some tinker mods on mine though. If you start upping things on it like fuel and what not she may not go to the distance, but with a respectful driver they are fine. I never use WOT on mine, if she bogs towing I downshift to get the strain off. I did 500 miles empty in it last month, loaded up with 22k trailer and then went another 650 miles back home a different way with no issue. It also depends on your truck and what your respect level with it is. Be smart about things, something looks worn out replace it, get it done and over with.
I have put over 120hrs on mine since September. She does get around a lot.
You can do some small stuff to give her some better air flow to help the ole girl breathe better.
74M35A2
326
Livonia, MI
The A2's get more than double the fuel economy. This is big if you really plan to stack on the mileage. The 8.3 is nearly half the size with a turbo, but same total hp potential (10hp higher if I remember correctly). The 250's have way more low end, the 8.3's have more top end (power), and the 8.3 is capable of higher top speed (RPM), as the engine is rated up to 3400rpm in its marine application. Tires are rated to 50mph or whatever, but the newer ones are rated at a higher speed, though they are slightly smaller. I'd consider all of this if buying a truck to put a lot of miles on. The money you save over buying an A2 may quickly be surpassed in fuel costs if you are really driving it a lot. 4mpg vs 10mpg. Both good engines. The 8.3 is supposedly a 600,000 mile engine, or so they say.
Scar59
41
Mt. Eden, KY
I have five trucks powered w/ the NHC 250. All stock configured, all will pull a house off the foundation. Very simple and reliable diesel power plant. Keep them serviced/maintained and operated within their envelope and they will out last you. Your grand kids will be playing w/ them.
maddeuce360
pittsburgh/pa
i was going back and forth for a bit about the a1 & a2 debate. I decided on the a1, after all i read the 250 seemed more time proven to me.
You guys have some good picks hauling, if i decide to use it to get more trucks. ill have lots of questions about how to transport a truck with a truck.
99nouns
17
Ocala, FL
Just take it easy in out of the cab, jumping off a 4 feet drop 6 times a day gets old really quick when your knees hurt.
71DeuceAK
416
Fairbanks, Alaska
This is a really interesting thread. I've always wondered how the numbers would stack up mileage-wise if one was used as a daily driver (not necessarily always carrying heavy loads, but still on the road all the time, every day more or less).
98G
Former SSG
4,418
Mileage -
5 mpg virtually all the time with the nh250. Empty at highway speed, or towbarring another truck with both of them having 10,000lbs in the beds.
8.3 liter turbodiesel much more variable. I've gotten as low as 7mpg with an M109A3 on tow bars behind it, or as high as 12mpg empty and cruising at highway speeds. Generally 9mpg around town.
Sample size is multiple trucks of each kind, and >10,000miles in each kind.
98G
Former SSG
4,418
Towbars, airlines, safety chains, tow lights.... and a healthy dose of caution.
simp5782
9,355
Mason, TN
And a fred flinstone access panel in the floor to help get some speed on hills with an A1.:whistle:
I did get about 7 to 8 with my A1 when I went to Albany last month. 410 miles on appx 55 gals. Granted I only drive about 56 to 60. 1850 to 2k rpms. I am in no hurry. I get there when I get there.
Jbulach
2,167
Sunman Indiana
My M925A2 averaged 4.62 mpg hauling stone on 150 mile test.
25 miles each way, 69 mph empty on interstate.
55 mph on state road loaded at 48,000 gross.
Haven't had a chance to het any good empty mpg numbers yet.
M925A2 with dump hoist
Karl kostman
889
Fargo ND
If I were looking at a 939 series truck that I needed to depend on daily I would most definitely be ONLY looking at the 855 Cummins (WITHOUT CTIS)! If the truck is treated with due respect, operated within its boundaries and maintenance id kept up this combination will go a long ways! We just had an in frame overhaul done on an 855 290 HP model and we had over 900K miles on that motor! All the Cummis I own are 855 based and I have never once had one leave me walking!
Karl
Jbulach
2,167
Sunman Indiana
You do not lock the steering wheel. The front wheels need to be able to follow the tow vehicle.
