- 1,813
- 1,514
- 113
- Orlando, FL
I hoping that with the prevalence of the these gas cans, someone actually already knows the answer. If not, then yes, the guesswork will begin.The outer diameter of the part that it fits on is 55mm, and since you have a broken one, you should be able to measure the diameter of the ring itself. With those two numbers, you should be able to go to Grainger or McMaster-Carr and find an O-ring that would fit. That is what I would do.
Based on the measurements above (0.210" cross section, ~2.00" ID), and according to these charts...Here’s what I came up with.
