motormayhem
- 18
- 18
- Tucson, AZ
Well I am in the process of hooking up the old filter block to get my water in fuel light back in operation. I also just finished checking fuel flow from the lift pump according to the tm and i doubled the minimum requirement. I am also installing a coolant temp gauge cause I dont trust the idiot light and while I was in there I noticed the rubber fuel line from the lift pump seems to be kinked pretty badly only when the air cleaner is on. I am thinking this might be the problem cause I flow tested it with the air cleaner off so I could get a bottle in there. I cant remember the last time I had the air cleaner off but it wasn't to long ago. I am going to get a new fuel line tomorrow and pressure test the fuel system and take it out for a spin. Also for the flow test I pumped about 1/2 quart of diesel into a container and it didn't have rtv in it so I think that might have been an unrelated freak thing.
