cucvrus
- 10,505
- 113
- Jonestown Pennsylvania
Check your 4WD light socket connection and then crawl under the truck and look at the right side of the upper transfer case. There is a 2 prong plug and switch. Unplug that and cross the 2 prongs of the wire connection. Does the light work? If it does the transfer case switch is bad. But if the light doesn't work now the task is to determine why the light is not on with the 2 prongs crossed. Use a cotter pin or a short jumper to cross the terminals. Good Luck and Report Back.
