What to use for sealing bolt threads?
todds112
Teton Valley, ID
Kind of a dumb question. I replaced the front side, front axle pinion seal. Replaced the gasket for the seal housing too. Used liberal amounts of RTV to seal everything up. I noticed today it appears to still be leaking a bit from some of the bolts that hold the seal housing to the diff. What should I used to seal up the bolt threads? I have some "Right Stuff" gasket maker. I also have some PFTE thread sealant. Obviously I want to be able to get the bolts out in the future easily if I have to.
gringeltaube
Staff Member
2,289
Montevideo/Uruguay
Yes, that one; or Loctite 587 RTV.
Actually any good silicone sealant will work OK, but before covering the bolt threads they need to be dry and clean!
Out of those 6 bolt holes only two (or maybe three, I forgot) are through-holes and need to be sealed well. Eventually screw the (sealed)bolt all the way in and back out, then clean threads and again apply sealant. Use very little or nothing at all where there are blind holes.
G.
todds112
Teton Valley, ID
Thanks guys, I noticed only a few holes seemed to go through. It looks like only 1 or maybe 2 are leaking. I'll start with those.
Woodsplinter, I have actually have that exact stuff unopened on the shelf. I'll give it a try.
1,168
I like Indian Head Shellac.
m16ty
210
Dickson,TN
I use this a bunch but have never tried it on threads. I know on a mating surface it can make the parts really hard to remove if you ever want to take it back off. How hard is it to remove a bolt coated with it?
I once had a industrial gearbox that leaked. We took it apart several times trying to stop the leak. We tried everything, all kinds of gaskets and all kinds of sealants. In a act of desperation, we cleaned up the surfaces and applied a liberal amount of Indian Head only (no gasket or anything). Fixed the leak.
1,168
Bolts remove fairly easy.
