What trailer is this?
maxpanic
South Jordan/UT
What's a fair price for one of these? Does this sort of trailer have a M number designation? so you could use one for a welder or a generator, anything else?
RealCavDog
12
Joplin, Missouri
I may be wrong, but I believe it is called an M200A1, Look at our favorite auction site under generator, and you see very similar units, rated at 2 1/2 ton, on the site , bare, and with gensets and welders.
Hope someone else can confirm or have other ideas !
gimpyrobb
dumpsterlandingfromorbit!
27,787
776
Cincy Ohio
Yup, a couple guys have even put deuce beds on them. They are rated for 7000lbs payload on paved roads.
Wildchild467
59
Milford / Michigan
how much are would a trailer chassis in that picture be worth? they must have different axles than the M105 trailers, correct? Obviously this trailer frame in the above picture has duals where the M105s are singled., but thats not what makes the rating different, is it?
Westech
CPL
6,104
210
cow farts, Wisconsin
min bid.. we just pulled 8 of them home for min bid. Different axle.. dual tires.. and 14 leaves in the springs and larger frame... Its not a 105 that is the difference.
