bikeman
- 503
- 113
- Ft. Bragg, NC
Looks like installation is actually covered in TB 43-0209, 31 OCT 1990 (available via https://liw.logsa.army.mil/etmapp/#/etm/search )If someone is on active, they can look up/get a copy of TB746-93-1. That TB covers marking of vehicles. It should have your answer as to where the marker would be placed.
The first doc shows a basic placement of the bridge Classification marker. The second Doc is the Regulation, here in Germany that covers bridge crossings. Hope it comes out.
----A Vehicle weight classification sign kit, as described herein, will be installed on the front of each vehicle...
These vehicle weight classification sign kits can be installed on vehicles in different ways. For example, in the case of Cargo Truck [M35 or M923 pictured] the sign can be installed on the brust guard, on the splash shield, or in an upright position on the fender. The choice of method is left to the using organization.
(1) Location.
(a) The classification sign will be installed on the vehicle in one of the following locations:
1. Right front fender.
2. Right side of Brush Guard.
3. Right front section of hull.
4. Right side of center front bumper splash shield
(b) The sign will be placed below the driver's line of vision and will be positioned so that it will not block headlamps, marker lights, blackout lights, air intakes, etc.
CAUTION
If it is found that the vehicle classification sign seriously obstructs airflow to the radiator, as indicated by engine overheating, remove sign from the brush guard and install sign elsewhere
