what would cause this failure of a crank?
1,123
I will vote lack of oil pressure.
1,168
Over-rev and or Over-torque(rev it up and dump the clutch). Better sideline all jeeps and get an analysis done at the Swiss Metals Lab. :wink:
It's amazing that a crank would break with numbers like these, Horsepower (actual @ 4,000 RPM)................60
Torque (max. @ 2,000 RPM).........................105 Lbs. Ft.
WW2Chevy
56
Bloomington, IL
Of particular concern are what appear to be circular gouges in the un-machined face of the crank. This is obviously not intended to be a wear surface, and yet appears to have been subjected to some pretty harsh wear. Did something allow or cause a lateral force on the crank, rather than the circular motion it is designed for??
kcimb
212
Fort Worth, Texas
Pogostick?
WW2Chevy
56
Bloomington, IL
kcimb said:
Pogostick?
Huh!?! :?
kcimb
212
Fort Worth, Texas
WW2Chevy said:
kcimb said:
Pogostick?
Huh!?! :?
Perhaps someone was using it as a pogostick.
Stretch44875
Super Jr. Moderator
Tiro, Ohio
I think the circular marks are from when it broke, and was rubbing against the other part of the crankshaft.
The pogo comment was a complete waste of space.
dittle
72
Albia, IA
Could just be metal fatigue. We had a farm tractor break a crankshaft in half during startup once. It was just a little 4 cylinder gas engine with 65 hp. Of course, Murphy's Law was in effect during the break......we had a hay barn catch fire and this was the tractor with the loader on it that we needed to unload the barn. aua
WillWagner
2,396
Monrovia, Ca.
Usually, if the crank breaks behind the #1 main it is a vibration damper issue....if the break is in front of the last main journal, be it a 4, 6, V6, V8, etc, it usually indicates a problem at the rear of the engine, like a flywheel/clutch issue.
Jones
Sacramento, California
Pattern of gouging appears to continue across fractured surface. If the gouging occured first then it's sharp, rough edges could have created stress risers.
Better shots of the fracture surface would help. If one area shows a darker tinge then it may have been cracked for some time and at some point just failed across the rest of the crank throw. A shock like dumping the clutch will put far higher loads on a part than high but constant torque.
Sheared vs. snapped vs. cracked surfaces each have their own distinctive "look". A little close-up study would probably reveal some tell-tale signs.
