What's missing in pic, plug? no plug?
lawdog1623
Texas
ok heres a puzzling question. logic stands to reason that if theres a threaded hole somewhere, theres supposed to be a plug in it. On the engine ive seen many of these plugs threaded into misc areas of the manifold, block etc. I crawled up under the m35a2 to trace leaks. I then noticed that at the bottom of the bell housing (where the flywheel is located) there are 2 plugs. Im not certain there are 2 but i thought i remembered seeing 2 of them. Then there is a large threaded hole that is quite large approximately the size of a silver dollar in between the two plugs. The other two are about the size of a quarter and these holes have square drive plugs. The largest hole that is missing the plug is directly in the bottom center of the housing that holds the flywheel. This particular hole is threaded and it appears as if theres supposed to be a plug there. I checked the tm's and cant find this detailed sufficiently (for me anyway) enough to give me any direction. Does anyone know if this area holds fluid, and if theres supposed to be a plug in it? Second question- can someone explain how i go about checking fluids in the transmission? What weight to use and how much? I havent downloaded this part of the tm yet and im on a computer at work. I wont be able to get it before my days off. I would like to figure this all out so i can do the work. Thanks
1,808
I see that you have not read the operators manual yet. I would suggest that you do as your truck has many other surprises. What you observed is correct as it is. Don't plug that hole. The TM explains it much better than I and you will be smarter for checking it out.
4,796
Like Kenny said, read the TM's. If I would have spent 2 minutes removing the plug on the bobber I got, I wouldn't have had to spend a half a day cleaning up the oil soaked clutch.
1,177
I wonder if he's talking about the emergency brake fluid drain plug?
1,177
Searching the forums is sometimes helpful.
1,131
Searching the forums is always helpful!
http://www.steelsoldiers.com/deuce/49900-missing-plug-here.html
http://www.steelsoldiers.com/deuce/35216-help-bad-pic-included.html
http://www.steelsoldiers.com/deuce/70530-flywheel-housing-bolt-missing.html
http://www.steelsoldiers.com/deuce/32914-there-supposed-something-hole.html
http://www.steelsoldiers.com/deuce/53977-whats-missing-here.html
http://www.steelsoldiers.com/deuce/53696-am-i-missing-something-transmission.html
http://www.steelsoldiers.com/deuce/22590-missing-plugs-bad.html
http://www.steelsoldiers.com/deuce/4248-missing-plug.html
1,177
And sometimes, reading the link before posting, is helpful. :doghead:
1,131
And sometimes, reading the link befre posting, is helpful. :doghead:
What makes you think I didn't read it?
Where'd you think I found all those links? I certainly didn't search for them, I am trying to fit in more around here.
rofl
lawdog1623
Texas
its definitely the fording plug on the bottom of the flywheel housing. I found it on a link after searching the forum. Come on guys! im still learning. Not trying to ruffle feathers.
73m819
320
gainesville, ga.
Instead of a smilly shooting self in head, how about one that shoots it self in the foot.
islandguydon
783
Michigan
I was under the impression it was the fording plug. Right next to it is a plug that goes no where but is threaded in. I learned before you go swimming you swap the plug into the open hole.
1,808
Lawdog, you need to stick around here for a while. It's nice to have members who can take a little ribbing without pouting. A+ to you Sir. Now, about that TM. . . . LOL
lawdog1623
Texas
Well to prove my devotion i comped out an hour from working the mean streets to read tm's. I SHALL NEVER ASK ANOTHER IGNORENT QUESTION!! I grovel at the foots of all here who are mighty and knowledgeable. I hereby designate myself ss latrine officer for 14 days. On a side note does anyone know how much coolant one of these things hold or how to check it? (insert future suicidal emoticon here)
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
My personal favorite is, "Hey, I just recovered my truck and drove it 30,000 miles home. How do I check the brake fluid?" but that one has been beaten to death
Warthog
232
OKC, OK
You might want to spend a few more minutes reading the Lube Order. It will have all the fluid types and quantities.
73m819
320
gainesville, ga.
OR this one "HELP, started the deuce, how do I shut it off", or this one "HELP, how do I start my deuce", could have been a lot worse like "WHAT IS THE RED BUTTON FOR"
