What's missing in pic, plug? no plug?
1,193
LO9-2320-209-12-1.pdf
LO9-2320-209-12-1 Lubrication Order for the M35 series.
TM9-2320-209-10-1.pdf
TM9-2320-209-10-1 Operation, Installation and Reference data for the M35 series, Operator Level.
TM9-2320-209-10-2.pdf
TM9-2320-209-10-2 Scheduled Maintenance Operator level M35 Multifuel.
TM9-2320-209-10-3.pdf
TM9-2320-209-10-3 Troubleshooting Operator level M35 Multifuel.
TM9-2320-209-10-4.pdf
TM9-2320-209-10-4 Maintenance Operator Level M35 Multifuel.
TM9-2320-209-20-1.pdf
TM9-2320-209-20-1 Scheduled maintenance organizational level M44 series 2-1/2 ton trucks.
TM9-2320-209-20-2-1.pdf
TM9-2320-209-20-2-1 Organization level - Troubleshooting Multifuel M35 Part 1 of 2.
TM9-2320-209-20-2-2.pdf
TM9-2320-209-20-2-2 Organization level - Troubleshooting Multifuel M35 Part 2 of 2.
TM9-2320-209-20-3-1.pdf
TM9-2320-209-20-3-1 Organization level - Maintenance M35 Multifuel Part 1 of 4.
TM9-2320-209-20-3-2.pdf
TM9-2320-209-20-3-2 Organization level - Maintenance M35 Multifuel Part 2 of 4.
TM9-2320-209-20-3-3.pdf
TM9-2320-209-20-3-3 Organization level - Maintenance M35 Multifuel Part 3 of 4.
TM9-2320-209-20-3-4.pdf
TM9-2320-209-20-3-4 Organization level - Maintenance M35 Multifuel Part 4 of 4.
TM9-2320-209-20P.pdf
TM9-2320-209-20P Organization level - Maintenance M35 Multifuel repair parts and special tools.
TM9-2320-209-34-1.pdf
TM9-2320-209-34-1 Troubleshooting Direct and General Support Levels.
TM9-2320-209-34-2-1.pdf
TM9-2320-209-34-2-1 Maintenance Direct Support and General Support M35 Multifuel 1 of 3.
TM9-2320-209-34-2-2.pdf
TM9-2320-209-34-2-2 Maintenance Direct Support and General Support M35 Multifuel 2 of 3.
TM9-2320-209-34-2-3.pdf
TM9-2320-209-34-2-3 Maintenance Direct Support and General Support M35 Multifuel 3 of 3.
TM9-2320-209-34P.pdf
TM9-2320-209-34P Direct and General Maintenance and Support Parts and Special tools.
TM9-2320-361-20.pdf
OK, now the burning questions: With all these different tech manuals, there's gotta be a whole lot of redundancies and overlapping of information. I understand a deuce is a complicated piece of equipment and requires a sizable amount of information to keep it running reliably and safely, but which, if any, of the TMs will cover everything needed to keep a regular old M35A2 running reliably and safely? Say for example I wanted to go to a print shop and have one of these PDF documents printed and bound so I can have a hard copy in the truck in a plastic bag (or two) under the driver's seat just in case. Which one should I shell out the $$ to have correlated, printed and bound?
:beer:
1,193
There is no such thing as one magic TM that will always help you.
They are not designed like that.
When talking truck TMs, simply think 3 levels.
Level one (basic), operators manual(how to drive and use the truck). ends in -10
Level two (mechanical repairs) the type of basic maintenance you might do at home. ends in -20
Level three (the most technical mechanical repairs) the type of things you would most likely take your vehicle to a professional repair shop for. ends in -34
And there are usually one or two that end in "P". Those are exploded parts views with all the part numbers listed.
The LO (lube order) tells you where and what fluids are used in your vehicle. ends in -12
There are variations of the ending numbers, but in general, the lower the ending number, the more basic it is.
steelandcanvas
87
Southwestern Idaho
If it were me, I think I'd have this one on board:
TM 9-2320-209-10-3
TECHNICAL MANUAL
TROUBLESHOOTING
OPERATOR LEVEL
2½-TON, 6x6, M44A1 AND M44A2 SERIES TRUCKS
(MULTIFUEL)
But, as Doghead previously stated, there is no one magic TM to have in the cab.
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
That's a very good explaination of the TM structure. You made it very easy to understand. I may have to use that in the generator sticky I'm working on.
randini
salt lake/utah
I am always impressed with everyone knowledge, and willingness to share. Thanks to all who contribute!! To Doghead, I am working on memorizing all the Manuals, will there be a written test later??:p
1,193
hmm, the PS magazines are written in cartoon form...
1,164
That is a great description doghead. thanks!
