OK, what's the secret for tightening the Deuce Park Brake cable adjusting nut? I'm talking about tightening the nut at the apply lever on the park brake assembly on the transfer case. I've run out of adjustment by cranking the handle on the in-cab park brake handle.
I've crawled under the truck and can see and feel the tightening nut and even get a 3/4" wrench on the nut, but there is not enough room the crank the wrench to tighten the nut. Between the cab and braces, I can turn the wrench about 1/6 turn, but all that does is twist the cable slightly. I suppose I can use a vise grip in the cable ferrule to minimize cable twist, but I still can't get enough swing on the wrench to move the nut, even though I still have plenty of adjustment length left on the threaded stud.
Can't do it from above with a 3/4" deep socket, there is a brace it the way so there is no way I can even get a socket it there. So what is the solution? Buy a stubby 3/4" combination wrench and hope I can get enough swing with that? I've dosed up the nut & threaded rod with carb & choke cleaner to loosen up the accumulated crud, but how do I turn that da!m nut?
