What's this hose for?
SRB1976
9
Hanna, Wyoming
Up underneath the dash of my M35a3. It looked lose so i moved it and two springs and a ball bearing fell out onto the floor. My low air buzzer and light was not working so I started looking for the problem and found this. The funny thing is the buzzer and light work now whether it's connected or not.
319
Lieutenant
49
Michigan
It's been a while since I had my A3 but I think there was a check valve in the tubing, although I never took it apart. Kept the pump from losing prime. It's easily traced if the pump is still attached to the underside of the instrument panel.
SRB1976
9
Hanna, Wyoming
The washers don't work anyway. It turns out the problem with the low air buzzer/light is in the accessory switch. I wiggle the switch around and the buzzer works. Probably just a little dirty.
