rolling18
- 77
- 28
- Portland, OR
they are perfect for boiling off H2o out of WMO too!! as well as "passive" heat... I had my oil up to 290F could go much hotter, but oil got too bubbly..Old school devices better known for eyebrow removal
They are a "doughnut" made from stainless that had a draft pipe and exhaust pipe sticking up out of a drum of water. Gasoline was dripped down the draft pipe and lit. The resulting draft will pull the flames down, through the doughnut and up the exhaust pipe, if properly lit. But putting too much gasoline in before lighting will flash back, usually taking all exposed hair with it.
They work well, heating 40 gallons of water in about an hour. Can be used for heating MRE entrees or washing dishes.
also, mine was the version that had the metal "disk" with hinges around the top for attachment to a "water buffalo"
took me a LOOONg time to figure out how to put the stove pipe together! wow1
