BugEyeBear
- 3
- 0
- Eastern Georgia
UPDATE:
I spoke with the repair shop this afternoon...
-They pulled the pass rear wheel bearings again, cleaned them off (removed all of that Moly grease), & inspected them carefully (all looked good!)
-They Repacked them with High Temp Lithium Grease (the type normally used for disk brakes)
-They Reinstalled bearings
-They Reset bearing preload, 150ft-lbs to seat bearings, then back-off, then 50ft-lbs, back off approx 1/8th turn, install lock/star washer, tighten lock nut .
-Just 1 good bend-over lock tab was left on each of the star/lock washers
(I will need to order some more before the next time I disassemble or re-preload the bearings)
-They did a road test at 50-55mph for an approx 20mile round trip
-They Checked Hub Temps immediately at return
Driver’s side rears: 80degreesF, & 78degreesF (this side remains completely untouched since this Deuce became mine)
Passenger’s side: 105degreesF in the very rear, 115degreesF in the front rear (this is the side that was just redone, due to the gear oil leak it had at purchase)
Temps seem to be better (temps were as high as 180degreesF when I drove it on Saturday)
MAYBE Temps will drop as things break in (seals wear, etc.), MAYBE not...
SO, I'm gonna pick it up tomorrow, do a road test of my own, check the temps of the hubs & of the brake drums & hope that none of the hubs is over 120-130 degrees F.
Others have stated that their hub's run 105degrees F to 130degrees F pretty regularly, so I think I'll be OK if I'm in this range.
I'm guessing that the fresh pass side seals DO cause some increased heat in the hubs, whereas I have no idea if the driver's side has worn seals, different seals, or possibly NO seals (let's hope not!).
IF the heat somehow degrades the seals , OR if the hubs start to get hotter than 130degrees F I'll probably end up tearing it all apart myself & doing the seal mod that is described by "Gringeltaube" in this related thread:
http://www.steelsoldiers.com/deuce/31749-hot-hub-3.html
However I have to think that the mod could be different for each wheel install, as there is no guarantee that the bearing & race dimensions installed are all the same. (could be different bearing suppliers)
It will be interesting to see if the temps drop over time (as some people have reported), OR (God Forbid) if the seals fail & I'm leaking fluid into the grease once again!
It just needs to be good enuf for the next 400 miles! I'll be home by then & I can then wrench on it myself!, IF necessary.
(IF you see a Duece on the side of the road this coming weekend in GA please be sure to stop & help! It might be ME!!) (I'm praying that "Sgt Murphy" takes a few days off while I make the journey!!)
I've spent ENUF $$$ on this recovery already!! So I'm hoping for smooth sailing from here on out! (But I DO have to confess that I took advantage of the situation & had the shop guys fix/check a few little nickel&dime things while it was in there... steering drag link adjustment, replace the turbo drain hose, check/top all fluids, fix a few oil leaks, check driveshaft bolts, check/adjust tire pressures, & look for anything else that might be "hidden"....) NORMALLY I'd do all of this stuff myself, but since I was spending extra $$ already, & having my road trip delayed by the unexpected repairs, I figured I'd make the most of it!!
I'll give it another good once over before hitting the road, but HOPEFULLY all of this now results in a very road-worthy Deuce!
SIDE NOTE: The mechanic used the blunt chisel method to tighten the lock nuts. He says he does this because using a socket tends to shear the keyway "tit" off the star/lock ring. To be honest, I'd probably prefer to use a toirquewrench and socket instead of a chisel because I do tend to believe that the lock nut has to be degraded by this method over time. BUT I'm no expert!! & I CERTAINLY didn't want to tell him how to do his job! (I felt I was ALREADY on the verge of doing that with the regrease & re-preload requests!) Nice guy! He was pretty receptive to my suggestions and put a lot of extra hours in on this job! But I did back up my suggestions with either a Maintenance Spec or a SteelSoldiiers reference!! So that gave me SOME additional credabiliity!
