wheel cylinders
rustystud
2,938
Woodinville, Washington
You can find the wheel cylinders all over the place, the problem is there all made in China ! So what I do is go and buy new cup seals from NAPA . Just the generic ones which are made in the U.S.A. Then I gut the new cylinders and install the new cup seals . This has worked for years now and no leaking wheel cylinders ! Make sure the wheel cylinders has the correct spring with the seal expander in them. If they don't then reuse your old ones.
dusterdeere
grove city Pa
thanks. I think I read on here about a guy taking the small nuts off of the hub to drum and just pull the drum off. is that a good idea or should I pull hub and drum at same time.
Tow4
646
Orlando, FL
You should pull the hub and drum together. The hub is in the way if you just pull the drum.
