Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
I have the potential to buy these wheels and tires for very cheap ($125 each)
My truck is not bobbed and per my understanding I'll need adapters. My worry is if they will fit with dual rear axles and not rub.
I would plan to do a hub flip and single it out with these.
The wheels pictured are 20x10" MRAP, 10 on 335mm center, 20-bolt, heavy duty steel construction and weighing about 170lbs. They would work well with adapters.
But those sand tires are way too big, measuring almost 49" O.D. Your distance between rear axles is only 48", so...................
Either modify your trailing arms, AKA "dogbones" as well as drive shafts, to get at least 50" C-C betw. rears.
Or stay with 46" tires.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
