Wheel Pattern For M998 Same As M1123???
I am looking at purchasing a set of 37" mil issue BFG tires on M1123 wheels for my M998.
Are the bolt patterns and such the same??
I hate to assume they are..
I am looking at buying the wheels and tires, frame rails (which I dont need), cross members (also dont need) and instrument cluster (dont need) for an asking price of $1250.
So then I'll be stuck with the rails and such. I'll basically be paying for the wheels and tires...and I want to be real sure they will fit since thats all I am really interested in buying.
I tried pricing a new tire thru Discount Tire and it was almost $700 and they would not mount it, so buying used, locally, is about my only option..
kblazer87
307
southeast Indiana
I would think with a little judicious shopping that you would be able to get what you want for less without having to buy all of those extraneous items.
As far as I know, all of the hummers use the 8 on 6.5 bolt pattern for the rims.
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
Kblazer87 is correct, bolt pattern is the same for all: 8 on 6.5".
Also true that one should be able to find a good set of 4 tires/wheels for less $$$.
And personally I'd much prefer the 24-bolt wheels over the 12-bolts; they are stronger and have a better valve stem.
G.
86humv
496
Texas
There are 2 types of 24 bolt wheels.....even spaced, and paired spaced which has the different valve stem.
The early and late 12 bolt and early 24 bolt all use the same stem.
