rlltide12
- 1
- 18
- NW Florida
I run US Wheel Stealth line. They have them in stock on summit's website.
Respectfully, in response to the gentleman from Alabama - I intend to run the HMMWV wheels because I want the beadlock capability so I can lower the tire pressure for better traction in snow or mud without danger of the tire breaking loose from the rim. I am assuming you know how these wheels are designed to work so I won't elaborate further. And besides, I just like the way the HMMWV wheels look.Is there any particular reason you are wanting to run hmmwv wheels? A set of steelies in the correct back spacing from someone like summit racing seems like the safer and probably cheaper idea. I know people run them without issues, but i just dont like the idea of wheel spacers. Too many failure points.
Not that my opinion maters, but I will share it anyway. I don't know you SC, but I am happy to read that you are enjoying the fruits of your labor. I encourage my parents to leave no trace, it's my turn to make it in life.But I don't care because I am spending my daughter's inheritance money.
Skinny - you and I have no problem. I just didn't appreciate the fellow from Alabama busting in like he did.Sorry for the hijack Sharecropper, I was curious to see what other sizes are successfully run. I too am kind of in the same boat. I currently run some really old Ford rims (probably from the late 70's) and now that my recently purchased Centramatics don't fit, I need to find a solution. It is down to HMMWV rims or new steelies. I really like the HMMWV for the same reasons you do but struggle with a decision between recentering, spacers, or sourcing DRW hubs.
It's just money, I can always make more
Again, sorry for the de-rail on my end.
Bunkerbuilder -Has anyone considered the leverage factor running spacers?
Having the weight of wheel and tire out two inches farther than factory engineered to operate may also be a consern for anyone putting safety before bling!
IE: the strength of the studs may be taxed when the weight is another two + or - inches the stress factor originally figured.
Bunkerbuilder -
Thanks for your comments. If I were planning to run my rig in a Baja race or planned to do serious rock crawling, then yes, I would have a slight concern about the leverage factor. However my truck has never been off-roaded and I don't intend to ever get it muddy. The key word is "intend". If for any reason I need to take it off road for an emergency situation or zombie attack, I want it ready to go. My truck sat on a National Guard base in Arizona for 25 years. It had 12,338 miles on it when I got it in 2010. I only drive it occassionally, it turned over 13,000 miles the last time I drove it. The truck stays locked up in my heated and cooled warehouse under tight security. It is, without a doubt, my most prized material possesion during my 64 years on this earth. We got 12" snow here last night. I thought about pulling it out for a little fun, however decided against it because the truck is so clean and warm. And besides, my knees are hurting too bad to climb up in the thing.
When you think about it, running spacers on the front is no different than running a dual rear wheel with a longer hub. So I am Ok with it.
