Jeepsinker
- 470
- 83
- Dry Creek, Louisiana
Bigger tires? The thing sits on 16.00s as it is. What is there that is bigger save for tractor tires or mining truck tires?
So when are you gonna get started on modding one now that the FEMTT is done?I feel that it would truly be a shame to bob such a perfectly beautiful beast of a truck!!!!!!
But then...... I'm probably a little prejudice.....since this is my all time favored truck!.....well factory stock truck that is..... lol
Soni
There was a HET on EBay recently with [I believe] a Deuce bed. Did anyone else see it?2nd edit: why Bob it? Why not remove the ramps and add a bed like a lot of people are doing with the 939 series truck tractors? Keep the 8x8 functionality and add a bed that you can load to the gills with 45000 lbs of stuff...
I've had the same thought.I'd make a big rollback out of it.
The differential ratio is 1.59:1, so I doubt it would even be able to move correctly.It you had a real smart machinist type fella, he might be able to make a set of replacement gears for the wheel end planetaries to get a higher ratio. That's one thought to make it more driver friendly. I don think you can just remove the planets and go direct drive. It would seem that any way you go would cost big money though.
